New software - Version 3.43
Postby Dataman (Daniel Smith) » 10 Sep 2018 11:06
Version 3.43 features the following amendments:
Improved performance: 2x faster MD5 hashsum calculation
Improved performance: 4,5x faster Byte Sum x8 checksum calculation of device buffer data
In General options added option for MD5 hashsum calculation of project files when loading/saving projects
Revert USB driver to 3.24
Dialog "Select device", "Save currently displayed device list to file..." bug fixed for 'OR' Fragments logical operator
Fixed: When loading projects for PICmicro devices, value of special PICmicro checksum is now correctly displayed in Programmer activity log
Fixed in "Create problem report" zip archive files of PG4UW(MC) Programmer activity logs:
- When using mode "Last days logs only" and files smaller than 1MB, these files are now
- Correctly added to zip archive, i.e. exactly with their file size, without unwanted remaining data
Fixed in PG4UWMC - for JAM/STAPL devices was modified device operation progress percentage indication, to be less than 100%, during device operation
Fixed PG4UWMC problem with incorrect value 'Obtain IP Automatically' displayed in dialog "Programmer network adapter configuration"
In PG4UWMC was fixed problem with incorrect checksums displayed under Site-s when "Each Site has its own project" mode is used
Actel/Microsemi SmartFusion devices, power-up procedure improved
Added adapter: BGA-Bottom-442
Added adapter: BGA-Bottom-476
Added adapter: BGA-Top-426 ZIF-CS
Added adapter: DIL16/QFN16-2.1 ZIF
Added adapter: DIL28W/TSSOP28 ZIF 170mil (id)
Added adapter: DIL48/QFP100-1.02 ZIF LPC-10
Altera EPCQL256 [FBGA24] (Quad), EPCQL256 [FBGA24], added Address mode selections
Atmel/Microchip ATmega3208/3209/4808/4809 devices, added ability to solve CRC check error
Atmel/Microchip ATtiny214/414/814/1614 in [SOIC14], insertion test modified
Atmel/Microchip ATtiny416/816/1616/3216 (ISP-SPI), added High voltage UPDI enable sequence
Atmel/Microchip ATtiny41x/81x/161x/321x devices, added ability to handle CRC check error
Atmel/Microchip ATtiny41x/81x/161x/321x devices in ZIF, High voltage UPDI enable implemented
Atmel/Microchip XMEGA A3/B3/C3/D3 series in [QFN64], Package drawing modified
Atmel/Microchip ATSAMD0x, ATSAMD1x, ATSAMD2x, ATSAMR2x, ATSAMC2x series, internal improvements of User Row handle routines
Azoteq IQS133, programming procedure improved
BGA-Bottom-231, improving of pgm parameters assignment
BGA-Bottom-219, improving of Automatic YES!
Cypress CY7C63723C [SOIC18], power-up procedure modified
Dallas/Maxim DS2502, programming of status register modified
Freescale Semic./NXP FXTH8709116T1 [QFN24], FXTH8715116T1 [QFN24], implemented "Preserve Trim values during Erase"
Giantec Semicond. GT25C256, ID check removed
GigaDevice GD25Q64C [WSON8 5x6], device name changed, old name GD25Q64C [WSON8]
GigaDevice GD25Q64C [WSON8 5x6] (QuadSPI), device name changed, old name GD25Q64C [WSON8] (QuadSPI)
Lattice GAL22V10D, adding of valid device ID code
Lattice ispLSI1032E [TQFP100], improving of pgm parameters assignment
Macronix MX25U6473F, Alt+S view/edit dialogue improved
Microchip dsPIC30F2010, set of FCKSM bits improved
Microchip dsPIC30F5011, erase procedure improved
Micron MT25QL256ABA8E, MT25QL256ABA1E, power-up improved
Micron/Numonyx/Intel JS28F128J3F [TSOP56], power-on/off procedure modified
Micron/Numonyx/Intel PC28F00AM29EWH [BGA64], power-up sequence modified
Motorola/Freescale Semic. MC68HC11L6, MC68HC711L6, increase of overcurrent protection limits
NEC/Renesas uPD70F3630, initialization procedure improved and programming speed increased
Renesas R5F51138AxFM [LFQFP64] Boot mode, erase procedure modified
Spansion S98FL512SxxMxxG0 [SO16] (Dual-Quad I/O), power-up procedure modified
STMicroelectronics BlueNRG-MS (ISP), power-up sequence improved
STMicroelectronics STM8L051F3P, power-up sequence improved
Tekmos TK87C751, programming procedure modified
TI (TMS) TMS320F281x, added mirroring of password locations between program buffer and the Alt+S window
Winbond W25Q128FWxxxG [WSON8 6x5], Verifying Status Register - error! listing improved
Winbond W25Q16JVxxxM-DTR, improving of information in Device Info
Winbond W25Q256JVxxQ, Alt+S view/edit dialogue improved, added Verifying Status Register
Winbond W25Q256JWxxQ [SOIC16], W25Q256JWxxQ (ISP), programming voltage reduced
Winbond W25Q64FWxxxG [SOIC8], W25Q64FWxxxG [SOIC8] (QuadSPI), W25Q64FWxxxQ [SOIC8], W25Q64FWxxxQ [SOIC8] (QuadSPI), changed device name and backward project compatibility correction
Winbond W74M25FVxxxQ [WSON8 8x6] (QuadSPI), W74M25JVxxxQ [WSON8 8x6] (QuadSPI), entering Root Key value in ASCII, Increment Monotonic Counter added
Zilog Z8Fxx8x, power-up sequence modified
ABOV Semiconductor AC30M1364 (ISP-SWD), ISP control signals(OK, ERROR) bug fixed
Analog devices ADUC7023xxxxx62I [LFCSP40], Unexpected error 1 [IEC:2, D:3C]! bug fixed
Atmel/Microchip ATtiny40x/41x/80x/81x/161x/321x, fuse bits programming and verification bug fixed
Atmel/Microchip ATtiny40x/41x/80x/81x/161x/321x, programming Flash and EEPROM occasional error bug fixed
Cypress CYAT817AZS72-3BFBA, verification of protection bug fixed
Dallas/Maxim DS28E01/DS28E02 in all packages, programming register page error bug fixed
Macronix MX25U6473F, Verifying Status Register - error! fixed
Macronix MX66U1G45G [SOP16] (Quad I/O), Programming registers - error! fixed
Microchip PIC16F526, programming CPDF bit bug fixed
Microchip PIC18LF26K22 (ISP-ext.VDD), Description of ISP connector pins bug fixed
Microchip PIC32MMxxxxGPM, programming of configuration bits bug fixed
Micron MT29F128G08CBCCBH6, part name fixed for all supported derivatives (was MT29F128G08CBBCBH6)
Micron MT29F1G08ABAFAWP-ITE [TSOP48], ONFI support fixed
National Semicond. DM74LS471, address pins bug fixed
NEC/Renesas uPD70F3630, programming bug fixed
Nuvoton MINI58TDE [QFN32], insertion test bug fixed
Silicon Laboratories C8051F7xx [QFN32], C8051F9xx [QFN32], insertion test bug fixed
STMicroelectronics STM32L4, interactions for PCROP settings in <AltS> menu fixed
TI (TMS) MSP430F5333, main memory size bug fixed
TI (TMS) MSP430FR57xx, main memory erase bug fixed
TI (TMS) TMS320F28075, TMS320F2837xS, Erase before programming bug fixed
Winbond W25Q128JVxxQ [SOIC8-200], Verifying Status Register - error! fixed
Winbond W25Q128FWxxxG [WSON8 6x5], Verifying device - error! fixed
Winbond W25Q32JVxxxQ [SOIC8], correction of changing device name in compatibility list
