New software - Version 3.48
Postby Dataman (Daniel Smith) » 08 Mar 2019 10:40
Added adapter: DIL48/QFP100-1.01 ZIF PIC-6
Added adapter: DIL48/TFBGA232 ZIF-CS.1 MT-AP00300
Users browsing this forum: No registered users and 28 guests
