Can you say my what a wiring für the Adaptorwiriing must i use it ?
Michael
Adapter for Programming / Reading ST 65640 EEprom on S4
Re: Adapter for Programming / Reading ST 65640 EEprom on S4
Hello Michael
I checked the S4 supported device list and the ST 65640 is not listed.
Are you sure the part name is correct?
Oh iss my mistake, the Name of the Ic ist NOT 65640
the Name ist 95640 form ST
Can i help you
Michael
Can i help you
Michael
Michael
That is supported on the S4. You will need the Serial Module and library V3.21 which is on our website.
That is correct, this is not the answer of my question
The S4 prommer say "use Adaptor", whitch wiring für the Adaptor must i use it ?
In the Textfile ( DOC ) from Serial Module ist ONLY wirering for 17C,xx;24cxx; 25,xx; 93Cxx; and other.
The ST95xxx Typ have NOT an Adaptor wirering, in the DOC list
Whitch Pins from the ST95640 must by connectet whis the Pin of the S4 prommer ( ADAPTOR )?
Michael
Michael
Michael,
The 95 series uses the same pins as the 25 series device.
