Hello Dataman,
Thought I'd just post this minor bug? that I've seen in the latest PG4UW software v3.23/04.2016.
When I use the "Fill Block" menu item from the "Buffer" dropdown menu and I fill any valid memory location(s) with any value and then I look at the memory window via the "View/Edit" menu item the wrong memory locataion(s) is/are highlighted in green.
I've notice this on several microchip PIC devices so I assume its a generic problem.
I'm using the PikPro programmer in Windows 7 Professional service pack 1.
Andy
PG4UW Minor Softare Bug?
Re: PG4UW Minor Softare Bug?
Hello Andy,
Thank you for your report. I have been able to recreate the situation as described and I have made our software engineers aware of it.
As soon as I hear back from them, I will post an update here.
Hi Neil,
Thanks for the prompt reply.
Cheers,
Andy
Cheers,
Andy
Hi Andy,
We have fixed the correct address range for highlighting of changed buffer blocks in the View/Edit buffer window after using the operation "Fill buffer block" (with pattern string) and when the current buffer view mode is x16.
URL: http://www.dataman.com/downloads/dl/fil ... ftware.zip
Version: 3.23h/04.2016
Hi Neil,
Thanks a lot
Andy
Thanks a lot
Andy
