Dataman 848 Universal Gang Programmer
Topics related to refurbished Programmers
Postby Dataman (Daniel Smith) » 09 Nov 2011 16:38
Refurbished Dataman 848 Universal Gang Programmer:
The Dataman 848 is a PC based parallel port universal gang programmer. It offers 8 fully isolated 48 pin ZIF sockets, extremely high throughput, standard 5 and 3 Volt chip support, device insertion and continuity check. With PC based design the programmer updates through software giving customers flexible and quick access to new chip support. The Dataman 848 supports EPROM, EEPROM, and FLASH. It is also Intel 87C5X, Amtel89C5x, and PIC16Cxx microprocessor compatible.
Features:
8 independant fully isolated 48 pin zif sockets
FLASH, EPROM, EEPROM and 87C5x, 89C5x, PIC16Cxx
Supports both 5V and 3V chips
High throughput, programs 8 pieces 8MB flash chips within 45 seconds
Semi-concurrent programming with auto-sensing/automatic self-start
Device insertion and continuity test
Independant modules allow flexible configuration and minimum down-time
Universal adaptors support 48 pin TSOP/44PSOP/40TSOP flash chips
Project file save/load function
Parallel port interface with auto switching power supply
Variable verify voltage with one/two pass
Specification
Supported Devices:
Dataman 848 supports over 14,000 devices from more than 50 manufacturers - with future devices being added monthly. Please download the full device list to verify your chip is supported.
Supported Device List
Package Includes:
Operation Voltage: 100VAC to 240VAC
Dimensions: 37 x 34 x 10cm
Weight: 7.5Kg
Moulded parallel cable (25-pin F to 25-pin M)
Moulded power cable
Driver software (Compatible with Windows 98, Windows 98SE, Windows ME, Windows NT and Windows 2000)
If you would like further information or purchasing details, please contact Dataman.
Return to “Programmers”
