New software - Version 3.63
Postby Dataman (Daniel Smith) » 01 Dec 2020 12:53
Added module: AP1 QFN48-1.02 ZIF PLD-1
Added module: AP1 QFP100-1.02 ZIF TXZ3-2
Added module: AP1 QFP48 ZIF LPC-1
AP1 QFP44-1.04 ZIF AVR-1, interface modified
AP1 QFN44-1.02 ZIF AVR-1, interface modified
Macronix MX25V4035F [USON8 2x3], added support
