Version 2.55 features the following amendments:
Atmel AT24C16B [MLP8], pinout bug fixed
Spansion S71GL016A, ID check modified
STmicroelectronics NAND08GW3B2CN [TSOP48], programming algorithm fixed
TI BUF08821, verify procedure bug fixed
Motorola/Freescale Semic. HC908JB: uploading algorithm bug fixed
Spansion S29Gl512P, programming procedure modified
ESFT F49L320, protection procedure modified
MT29C1G12MAVRAJA [TFBGA137] programming algorithm fixed
Sanyo LE25FW106M, memory size bug fixed
STMicroelectronics ST72F321J7T, erasing bug fixed
Lattice ispPAC-CLK5xxx [TQFP100], insertion test bug fixed, modification of code
Analog Devices ADuC841/842/843 [LFCSP56], programming bug fixed
Micron MT28F800B5, erase procedure bug fixed
Xilinx XCR3xxxXL, changing of overcurrent protection parameters
AT24xxx [dBGA2-8U4-1], [dBGA-8U1], [dBGA-8U6], pinout bug fixed
Spansion S29GL256N (x16), programming procedure of SecSi sector bug fixed
Intel RC28F256J3C and PC28F256J3C, wrong converter information fixed
STMicroelectronics ST72F321R6T [TQFP64], option bytes programming bug fixed
SunplusIT SPCP866E2A, blank check procedure bug fixed
Philips/NXP P89LPC954, device size and menu bug fixed
Atmel AT91SAM7xx, algorithm bug fixed
Macronix MX25Lxx35D (DualSPI,QuadSPI), Status Register programming bug fixed
Atmel ATtiny25/45/85 [TSSOP8], Wrong package name and convertor number fixed
Atmel ATtiny28L/V [MLF32], Wrong package name and convertor number fixed
Nuvoton N79E342, ID check procedure modified
NEC uPD78F0034B, erase procedure bug fixed
Fujitsu MB89P637P, socket converter type bug fixed
Philips/NXP P89LPC925 (ISP-ICP), verify procedure modification
Philips/NXP P89V51RD2 (ISP), programming algorithm improved
Lattice ispPAC-CLK5xxx [TQFP100], improving of package information assignment
STMicroelectronics M29W320DB, programming algorithm improved
SST39LF020 [TSOP32], insertion test procedure improved
Altera MAX II, MAX 7000B, improving of POF files loading
Motorola/Freescale Semic. HC08, HCS08, RS08, trimming algorithms improvement
STMicroelectronics ST7FLITE09Y0M [SO16], added feature for additional load of option byte file generated by ST7 visual programmer
Toshiba TMP91FY42FG, algorithms modified to achieve higher reliability of programming
Toshiba TMP91FY42FG, other programming algorithm modification
SST SST34WA1602xxxxMVJ, programming algorithm modification
SunplusIT SPCP868A programming reliability improved
Spansion S29GL512N (x16), programming algorithm for x16 mode improved
NEC uPD78F1146, programming speed increased
EM Microelectronic EM4176/EM6869, programming speed increased (algorithm for USB connection to PC)
Toshiba TMP91FY42FG, programming algorithm modified
Amic A29800, programming algorithm modified
Altera EPM7032S, changing of overcurrent protection parameters
Microchip PIC16F785, PICmicro checksum calculation added
Enhanced support (check, read, verify) of write protection feature enabled for STR7xx devices. From that reason, some stricter demands on target CPU boot modes involved for ISP modes
Infineon XC88x devices, programming algorithm improved
New software - Version 2.55
