Version 3.00 features the following amendments:
Completely rewritten device serialization engine to achieve device multiprogramming serialization over network when using multiprogramming programmers connected to more computers and controlled by one PG4UWMC.
Fixed bug that caused last serial record [...] in file of "From-file serialization" to be ignored. Serialization data for the last item might be not used, and no error was reported by programmer control software.
Fixed empty checksum records in Programmer activity log for device Intel RD48F4400L0YBP0.
Fixed in PG4UWMC - checksum indication for multiprojects now displays master multiproject checksum only. No partial checksums of subprojects included in multiproject are displayed.
Fixed undesirable device settings and secondary buffers content reset after Selftest, SelftestPlus and Selftest ISP connector. Also the test functions are disabled when Protected mode active.
Improved programming adapters/modules identification
In PG4UWMC fixed error "An invalid character was found in text content" Error could sometimes occur while saving program configuration to XML file.
Altera EP6xx family, programming algorithm improved
Atmel AT32UC3L064/32/16, code optimization
Atmel ATtiny4/5/9/10 [UDFN8], insertion test modified
Atmel AVR32 ATUCxxD3/D4/UC3C family, added user page words 0 into "View/Edit options and security" window
Atmel AVR32 family, new design of "View/Edit options and security" (ALT+S) windows
Atmel AVR32 UC3L/L3U/L4U family, added user page words 0 and 1 into "View/Edit options and security" window
BGA-Bottom-231, Automatic YES! improved
Catalyst/ON Semiconductor CAT24C16, programming and verifying procedure improved
Freescale Semic. MC56F8025 [LQFP44], algorithm improved
Freescale Semic. MC9S12XE family, new Device ID added
Freescale Semic. MPC5517S [LQFP176], "include TRIM value during verify" feature added
Freescale Semic. MPC5645S [LQFP208], new device ID added
Freescale Semic. MPC5645S [LQFP208], power-up sequence changed
Freescale Semic. S9S08SG16 [TSSOP28], erasing procedure improvement
Fujitsu MB95630 Series, added programmable addresses 0xFFBB, 0xFFBE, 0xFFBF
Fujitsu MB9A11x, MB9A13x, MB9A31x Series, reading/verifying speed increased
Fujitsu MB9B510/410/310/110 Series, implementation of ECC data verifying
GreenPeak devices, ID check modified
Infineon PX3743DDQ [QFN48], improved load psf file and calculate CRC
Intel RD48F4400L0YBP0 [SCSP137], read/verify improved
IR IR3570A, read algorithm added
Lattice LCMXO2-2000HC [FTBGA256], pgm. parameter assignment improved
Lattice LCMXO2-2000HC [TQFP100], pgm. parameter assignment improved
Micron MT29F1G08ABBEAH4 [VFBGA63], verify operation stability improved
Macronix MX25L1606E, programming algorithm improved
Macronix MX25L4006E [SOP8-150] (Dual O), programming operation stability improved
Maxim MX30LF1G08AA [FBGA63] (JAB-01), algorithm modification upon user's request
Microchip PIC24FJ64GA004 Family, added set of configuration bits SOSCSEL and WUTSEL
Microchip PIC32MX6xxx, added set of configuration bit DEBUG
NAND flash devices, added default pins excluded from sensing on Automatic YES! for BGA adapters
NAND flash devices, Quick Program option removed from Access Method menu
Numonyx PC28F00AM29EWL [BGA64], programming algorithm modified
Renesas/Mitsubishi M38039FFHKP, programming modified
Renesas/Mitsubishi M38507F8ASP, power-up modified
Renesas/Mitsubishi M38507F8ASP [SDIP42], improving of verify after programming action
Renesas R5F10xLxxFB, programming adapter DIL48/LQFP64-2 ZIF R5F-3 test improved
Samsung HART-m310 (ISP-SPI)/HART-i910 (ISP-SPI), added settings - maximum/80%/60%/40%/20%/10% of maximum for clock signal frequency SPI
Samsung HART-m310 (ISP-SPI)/HART-i910 (ISP-SPI), added settings - Reset release to actions start delay
Samsung S3F94x4, verify routine modified
Serial Flash devices in enhanced mode (Dual and Quad SPI, Dual and Quad I/O), programming/reading procedure improved
Silicon Laboratories C8051F30x (ISP), added 500k/250k/100k for clock signal frequency C2CK
Spansion S25FL256SxxBxxY0 [BGA24] (QuadSPI), S25FL256SxxMxx00 [SO16] (QuadSPI), read procedure improved
Spansion S71WS128PB0HF3S [FBGA84], programming procedure improved
Spansion S71WS128PC0HF3S [FBGA84], programming procedure improved
Spansion S71WS128PD0HF3S [FBGA84], programming procedure improved
Spansion S71WS256PC0HF3S [FBGA84], programming procedure improved
Spansion S71WS256PD0HF3S [FBGA84], programming procedure improved
Spansion S71WS512PC0HF3T [FBGA84], programming procedure improved
Spansion S71WS512PD0HF3T [FBGA84], programming procedure improved
SST SST39SF040, read/verify action reliability improved
Static RAM, "Delay between write and verify" stability improved
STMicroelectronics M29W320EB [TSOP48], programming procedure improved
STMicroelectronics SPC560B64 [LQFP176], maximum current value during power-up increased
STMicroelectronics STM8 devices, option bytes improved
STMicroelectronics STM8S005K6T [LQFP32], power-up modified
TI (TMS) LM3S1811, verifying device improved
TI (TMS) LM3S3J26, verify OTP Registers improved
TI (TMS) MSP430F51xx, verifying device improved
TI (TMS) TIBPAL20L8-15, pgm. parameter assignment improved
Winbond W25Q32BV (dc>=1023) [SOIC8] (QuadSPI), programming algorithm improved
Altera EP18xx [PGA68](ADP ET), bug fixed, adding information about correct insertion of a device into adapter
Altera EPM7064AE [TQFP100], insertion test bug fixed
Atmel/Adesto Techn. AT45DBxxxD family, Programming Config register - error! fixed
Atmel ATSAM3Nxxx [LQFP48], programming procedure bug fixed
Atmel AVR8 family, write of the calibration value bug fixed
Atmel AVR32 family, communication hazard bug fixed
Atmel AVR32 family, the inability to erase the device, when security bit is set bug fixed
Atmel AVR32 UC3B family, GP fuses programming bug causing sporadic IDcode corruption fixed
Atmel AVR32 UC3C family, secure fuse options bug fixed in "View/Edit options and security" window (ALT+S)
Atmel AVR32 UC3L family, secure fuse options bug fixed in "View/Edit options and security" window (ALT+S)
EM Microelectronic EM6819Fx, Custom generator serialization bug fixed
Enhanced mode of some Serial Flash devices (Dual and Quad SPI, Dual and Quad I/O), programming error fixed if "Device end" address has been changed
Eon EN39SL801 [WFBGA48], "Unexpected error 1 [IEC:2, D:04]!" bug fixed
Freescale Semic. MCF52xx family, edit of Sector list to erase problem fixed
Freescale Semic. MCF52xx family, sector erase error fixed
Freescale Semic. MKL05Z32 [QFN32], device insertion test error fixed
Intel D27513, ID check bug fixed
IR IR3570A/B, verification procedure bug fixed
Microchip dsPIC33EP128GP506, verification procedure bug fixed
Microchip PIC16F1508/1509, set of configuration bits FOSC bug fixed
Microchip PIC16F15xx, programming of configuration bits bug fixed
Microchip PIC16F6xx, verification procedure bug fixed
Microchip PIC16F88x, Blank Check procedure bug fixed
NEC/Renesas uPD70F323x, programming of security settings bug fixed
NEC/Renesas uPD78F04xx, power-off procedure bug fixed
Nuvoton MINI51xxx [QFN33], programming adapter test error bug fixed
Nuvoton W78E516D [LQFP48], insertion test procedure bug fixed
NXP LPC11xx/yyy [HVQFN33 (5x5)], programming adapter test error bug fixed
Renesas R5F56218 boot area programming bug fixed
Spansion S34ML04G200Bxx00 [BGA63], spare area size fixed (correct: 128 bytes, was: 64 bytes)
Spansion S34MLxxx and S34MSxxx device lines, invalid blocks identification procedure fixed (based on changes in datasheets)
STMicroelectronics SPC560B64 [LQFP176], blank verify setting error from loaded project fixed
Toshiba TC58NVG6D2GTA00 [TSOP48], partname fixed (was TH58NVG6D2GTA00 [TSOP48])
Xilinx XC3S-AN family, Programming Config register - error! fixed
Zilog Z86E23/61/63 [PLCC44], insertion test bug fixed
New software - Version 3.00
Users browsing this forum: Google [Bot] and 1 guest
