New software - Version 3.37
Postby Dataman (Daniel Smith) » 22 Dec 2017 16:29
ISSI IS25LP080D [SOIC8-200] (Quad I/O), IS25LP080D [SOIC8-200], added support
Macronix KH25xxx devices in USON8 2x3mm package, removed adp. DIL8/QFN8-4 ZIF-CS and DIL8/QFN8-4 ZIF-CS SFlash-1
Macronix MX25L25645GXD [BGA24] (Quad I/O), added support
Macronix MX25xxx devices in USON8 2x3mm package, removed adp. DIL8/QFN8-4 ZIF-CS and DIL8/QFN8-4 ZIF-CS SFlash-1
Micron MT25QL128ABA1E [SO8W] (Quad I/O), added support
