New software - Version 3.44
Posted: 12 Oct 2018 14:25
Fixed in PG4UWMC for standalone programmers - "Search programmer" dialog is now displayed correctly,
Fixed in PG4UWMC click on "Run what" button displays message containing information "what to do"
Fixed in PG4UWMC serialization numbers are now displayed for each programming Site also in mode of independent projects for each Site
Fixed in PG4UWMC serious hazard, that causes incorrect project data loading with result OK in situation, when previously loaded project was not successful due to error: "Invalid size or check sum of file or unsupported compression format - Native error: 00008"
Added adapter: DIL48/PLCC68 ZIF PLD-4
Added adapter: DIL48/QFN33 ZIF-CS module BT121-1
Added adapter: DIL48/QFN40-1.02 ZIF TPS40-1
Added adapter: DIL48/TSSOP14 ZIF STM32
