New software - Version 3.50
Posted: 30 May 2019 14:07
Added module: AP1 BGA176-3 ZIF STM32-1
Added module: AP1 QFN56-1.02 ZIF CY-2
Added module: AP1 QFN8-5.02a ZIF eSD-1
ISSI IS25WP016-J [USON8 2x3], added support
