Version 2.74 features the following amendments:
Installer, improving for Windows 7
Added support of new PSF file format
Added list of pins excluded from Automatic YES! pins sensing for each BGA socket adapter
Button 'Clear statistics' is disabled in software, if action is running on any site
File loading for Jam and STAPL player improved
Fixed bug in Automatic YES!
Improvement of buffer dialogs (Erase, Fill random. Fill string)
Improvement of dialogs Buffer/Erase, Buffer/Fill random data, Buffer/Fill, Buffer/Copy block, Buffer/Move block, added option to define custom address range, save history of inserted values
Help messages for Automatic YES! feature improved
Help for statistic feature improvement
JEDEC file (*.JED) loading improvement
Loading project with association file modified
Modification of project checksum mode detection for project created in software version older than 2.72
Renamed menu items Buffer/Erase... to Buffer/Erase block... / Buffer/Fill random data... to Buffer/Fill block with random data...
setting for indication of state when device access is done and SW waits for inserting a new device (in Automatic YES! mode) moved from Automatic YES! dialogue to General Option dialogue.
Updated library file remotelb.dll about SEND_CMD_GetDev_Checksum_CINDEX function
Atmel ATtiny13, added ability to write the default factory calibration value of 4,8MHz RC oscillator
Cypress CY2292F, JEDEC file loading improvement
EM Microelectronic EM6819Fx, HEX file loading improvement
Finisar XFP, power up procedure improvement
Hitachi HD64F36079L, programming procedure modified
Hynix H27UBG8T2A [TSOP48], read/verify operation reliability improved
Hynix H8BES0UQ0MCR [FBGA137], read/verify procedure improved
Macronix MX29GL512EHXF [LFBGA64], MX29GL512ELXF [LFBGA64], power up modified
Microchip dsPIC33FJ128GP310A, verification procedure improved
Microchip PIC24FJ64GA006, change the communication speed
Microchip PIC12F1xxx, PIC16F1xxx, for (ISP-ext.VDD) added Low Voltage Programming mode
Microchip PIC24F16KAxxx, power-up procedure improved
Microchip PIC12C671, PICMicro checksum calculation added
Microchip PIC24HJ64GP202, blank check procedure improved
Microchip PIC24HJ64GP202, erase procedure improved
Microchip PIC24HJ64GP202, programming procedure improved
Microchip PIC32MX695Fxxx, verification procedure improved
NEC uPD70F3453 (ISP-SPI), power-up procedure improved
Panasonic MN101EF31G [LQFP80], Security Key feature added
Philips P87C51, programming lock bit 3 added
Silicon Laborat. C8051F023 (ISP), improving of JTAG actions stability
Spansion MBM29QM12DH60PCN [TSOP56], power-up modified and erase improved
Spansion S29GL128PxxFxx01 [FBGA64]x16, power up modified
TI(TMS) TMS320F28015, added feature of separate password programming
Winbond W25Q32BV, changed device names from W25Q32BV to W25Q32BV (dc<1023) and backward project compatibility correction
Intel EPROM, added devices with package marking a temperature range
For R8C devices in ISP mode, pins description in device info window improved
NAND flash devices - a bug fixed in new invalid block processing ("Error - required number of blocks not processed due to invalid block(s) occurrence" was generated in error)
NAND flash devices - Read ONFI parameters page feature added
NAND flash devices - Other Hamming ECC algorithm support added (ECC - Hamming (2 x 256 Byte Frame) variant 2)
Atmel AT45DB642D [CASON8], 'Verifying Security Register - error!' fixed
Infineon/Siemens XC164CS-32F, ID check error fixed
Intel RC28F256K3C [Easy BGA64], programming procedure bug fixed
Intel E28F320J3A, programming error fixed
Freescale Semic. MC9S08FLx, trimming bug fixed
Freescale Semic. MC9S12E64, ID check error fixed
Freescale Semic. MC9S12XDG128 [QFP80], programming bug fixed
Fujitsu MB96F386RSA, power-up sequence modified
Macronix MX29LV128MH [TSOP56] x16, sector unprotect operation bug fixed
Microchip PIC12F617, configuration bits programming procedure bug fixed
Microchip PIC18FxxK20, erase procedure bug fixed
Microchip PIC10Fxxx, PIC12F6xx, Device operation Options bug fixed
Microchip 24LC65 (ISP), edevopt fatal error bug fixed
Microchip PIC12C671, Device operation options bug fixed
Microchip PIC18F67J11, set of configuration bits bug fixed
Samsung S3F84I9 [SDIP43], pinout bug fixed
Samsung K8P5615UQA [TSOP56], Unexpected error 1 [IEC:1, D:10] in sector erase fixed
Sharp LH28F128BFHED-PWTLT2, verification bug fixed
STMicroelectronics STM32F1xx (communication line), EDevOpt Fatal error bug fixed
STMicroelectronics STM32F1xx (low density): write protection programming bug fixed
TI (TMS) MSP430F47173, ID check error fixed
TI (TMS) LM3S3634, programming bug fixed
TI (TMS) LM3S3634, read bug fixed
Toshiba T5CN5 [LQFP100], programming bug fixed
Winbond W39L010 [STSOP32], insertion test bug fixed
Bug fixed in device name Toshiba TMP86FM42LUG. Right name is Toshiba TMP89FM42LUG
DIL48/QFN20-1 ZIF-CS STM8-1 socket converter, problem with 'Automatic YES' fixed
Fixed random bug for HT48F devices family
New software - Version 2.74
