New software - Version 3.56
Postby Dataman (Daniel Smith) » 04 Feb 2020 12:46
Actel/Microsemi A2F500M3G [FBGA484](STP), improving of overcurrent protection system
Added module: AP1 QFN32-1.02 ZIF NUC-3
Added module: AP1 QFN48-2.02 ZIF PS-1
Added module: AP1 QFP80-1.03 ZIF MN103-2
Added module: AP1 WLCSP94-1 ZIF nRF-4
Atmel/Microchip ATSAM3X8CA [LQFP100], initialization procedure improved
Micron MT29F128G08AMAAAC5 [VLGA52], pins assignment fixed (was 2x CE# only)
Spansion/Cypress S6E1C1xD0AGV2 [LQFP64], S6E1C3xD0AGV2 [LQFP64], insertion test bug fixed
