Not able to program Hitachi HD64F3337YF16
Yuvaraj_uchi
Postby Yuvaraj_uchi » 04 Sep 2020 06:11
We are not able to program Hitachi HD64F3337YF16. Do you have any suggestion?
Please check the attached error report.
PG4UW_LOG_windows_content_1176-04694.zip
Error report
(563.68 KiB) Downloaded 311 times
Re: Not able to program Hitachi HD64F3337YF16
Postby Dataman (Neil Parker) » 04 Sep 2020 10:00
Hello Yuvaraj_uchi,
Thank you for posting on our users forum. Can you update the software to the latest version as we are continually making improvements. If you could then run the Selftest... from the Programmer menu, using the diagnostic pod included with the programmer and let me know the result?
Please also confirm that you have the DIL32/QFP80 ZIF HS3334ESHF1H adaptor socket that is required for this device.
Yuvaraj_uchi
Postby Yuvaraj_uchi » 04 Sep 2020 13:50
Hello Neil Parker,
Thanks for the quick response. Let me check and update you.
Yuvaraj_uchi
Postby Yuvaraj_uchi » 10 Sep 2020 14:46
Hello Neil Parker,
Please find the attached report after running self test.
Let me know the next step.
Self Test report
(30.42 KiB) Downloaded 304 times
Postby Dataman (Neil Parker) » 10 Sep 2020 15:03
As a first step, please confirm that you have checked and eliminated the following points mentioned in the log file:
Selftesting procedure doesn't detect completely inserted the 48 Pins Diagnostic pod - Type I in the ZIF socket of the programmer.
Possible reasons of missing connections:
- The Diagnostic pod is not inserted into the ZIF socket or is not properly inserted
- The ZIF socket of the programmer is dirty and has bad contacts
- The programmer is damaged
- The Diagnostic pod is defective
Yuvaraj_uchi
Postby Yuvaraj_uchi » 18 Sep 2020 15:39
Hai,
I would like to inform you that in the software read blank & verify functions are working and the other two (erase & program) are not working, which shows that the reasons for missing connections.
Do you have any suggestions?
Postby Dataman (Neil Parker) » 18 Sep 2020 15:49
Thank you for the information but we first need to establish why the Selftest... is failing to run on this programmer. Were you able to check each point mentioned below and eliminate each one as a cause of the error?
Please confirm that you have the DIL32/QFP80 ZIF HS3334ESHF1H adaptor socket that is required for this device.
Return to “Dataman 48Pro2”
