I have an STB that use TE28F160C3BD70.
I desolder the chip than read it content using 48XP (with adapter).
Then I save the data into file.
I solder the IC again into the main board.
But now The STB is no working .... I ask the STB Manufacturer,
and they say that the Flash IC content is corrupted.
Well can you please tell me what's wrong here ?
Does the 48XP support this chip ? Or I miss something in doing that ?
Thank you
Jon
28F160 problem
Re: 28F160 problem
Jon,
That device is supported on the D48XP programmer. Are you using the SDP-UNIV-48TS adaptor or equivalent?
Have you set the correct configurations from the Config menu (ALT + G) and also have you then applied these configurations settings by hitting the Prot. button after programming the main data into the device?
