Added adapter: Bottom R-TSOP32 NOR-1
Added adapter: DIL48/BGA265-1 ZIF STM32H-1
Added adapter: DIL48/BGA64-2.3 ZIF NOR-5
Added adapter: DIL48/QFP112-1.03 ZIF R5F-2
Added adapter: DIL48/QFN40-1.02 ZIF TCA8-1
Added adapter: DIL48/QFN40-2.02 ZIF IDT49V-1
Added adapter: DIL48/QFN40-2.02 ZIF TPS53-5
Added adapter: DIL48/QFN48-2.02 ZIF CY-6
Added adapter: DIL48/QFN48-2.02 ZIF TPS53-3
Added adapter: DIL48/QFP80-1.02 ZIF CY-1
Added adapter: DIL48/SSOP10-120 ZIF MS51-1
Added adapter: DIL48/SSOP56 ZIF-CS NOR-1
Added adapter: DIL48/WLCSP36-7 ZIF-CS PLD-1
Adapter DIL48/QFN68-1.02 ZIF STM32WB-1 modified
Adapters DIL8/BGA24-1 ZIF SFlash-1b, DIL8/BGA24-2 ZIF SFlash-1b and DIL16W/SOIC16 ZIF 300mil SFlash-1b enabled as an alternative for serial NAND
AutomaticYES! for DIL48/BGA265-1 ZIF STM32H-1 modified
Modified adapter: DIL48/WLCSP25-3 ZIF STM32G-1
Adapter DIL8/BGA8-2 ZIF-CS, insertion test bug fixed
New software - Version 3.70
Users browsing this forum: Ahrefs [Bot] and 15 guests
