New software - Version 3.71
Posted: 01 Nov 2021 15:24
Version 3.71 features the following amendments:
Display "In circuit programming" dialogs fixed for remote control
Added module: AP1 BGA-0620/0581
Added module: AP1 QFN32-1 ZIF-CS
Added module: AP1 QFN40-2.02 ZIF ISL-2
Added module: AP1 QFN44-1.02 ZIF XRP-1
Added module: AP1 QFN8-9 ZIF SFlash-1b
Added module: AP1 QFP64-1.02 ZIF R7FA-1
Atmel AT32UC3A/UC3B family, Blank check procedure stability improved
Azoteq IQS211x, IQS231x, add recognition of .iqs file
Infineon XMC14xx [VQFN48], added support
Intel/Altera 10M02DC [WLCSP36], device info improved, adding of package modification information
ISSI IS25WP512M-RH [TFBGA24], added support
Lattice MachXO/MachXO2/MachXO3/MachXO3D, device info improved, adding of erase before programming information
Macronix MX25L25645GXD, improved Protected memory options display
Macronix MX25Lxxx/MX25Uxxx/MX66Lxxx/MX66Uxxx family, displaying of information about Verifying Registers - error! improved
Microchip dsPIC33CK256MP205, verification mask for CFG improved
Microchip PIC18FxxQ43, load/save hex file improved
Microchip PIC32CM series, custom HEX file load procedure added
MPS MP2975, MP2978, added recognition of different type .txt file
NEC/Renesas uPD78F0988A, power-up sequence modified
Puya Semiconductor P25Qxxx/PY25Qxxx family, displaying of information about Verifying Registers - error! improved
Renesas M38039FF (ISP-UART), power-up and recommended connection modified
Renesas R7F701071xx (ISP-SPI), description of ISP connector pins improved
Renesas R7FS5D97CxA01CLK [LGA145](EPS), programming modified
Renesas/Intersil ISL69259, programming adapter/module changed
STMicroelectronics BlueNRG-232, programming procedure improved + added independent programming option for readout protection
STMicroelectronics STM32H7xx, algorithms modified due to support devices with gap between Flash banks
TI (TMS) TM4C123xxx in LQFP64, LQFP100, LQFP144, programming operation speed-up
TI (TMS) UCD90xxx (D), UCD92xx (D), reliability of read improved
Nuvoton ML51TB9AE and ML51PB9AE, ID check bug fixed
STMicroelectronics STM32H7xx (ISP-xxx), fixed program parallelism voltage minimum value (to 1.8V)
