Added module: AP1 BGA100-1.02 ZIF eMMC-1
Added module: AP1 BGA144-9 ZIF STM32-1
Added module: AP1 QFN32-1.02 ZIF FL-1
Added module: AP1 QFP128-1.02 ZIF M16C-1
Added module: AP1 QFP144 ZIF STM32-2 (LD)
Added module: AP1 QFP48 ZIF STM32-3 (LD)
Added module: AP1 SOT23-6 ZIF TP-2
Epson S1C17611 [QFP12-48], Erase procedure modified
Infineon SAF-XE164H-96Fxxx [LQFP100], IDcheck procedure modified
ISSI IS25WP032D-J [USON8 4x3] (Quad I/O), IS25WP032D-J [USON8 4x3], added support for 48Pro2AP, 448Pro2AP, 448Pro2AP-AU
Micron MT35XU01GBBA1G12 [T-PBGA24] (Octa I/O), power up sequence improved
Micron MTFC8GAMALBH [TFBGA153], added programming options for Extended CSD register
Puya Semiconductor P25Q80H [SOP8-150] (Quad I/O), added support for 48Pro2AP, 448Pro2AP, 448Pro2AP-AU and read operation improved
Renesas R7F701442xxFB [LQFP176], R7F701400 [LQFP100], programming procedure for DFM improved
AP1 SOT23-6 ZIF TP-2, fixed incorrect checking of serial number
Atmel/Microchip ATSAMC21J18A [WLCSP56], ID check error bug fixed
Micron MT35XU01GBBA1G12 [T-PBGA24] (Octa I/O), verify error fixed
Renesas R5F72543RKBGV [BGA272], Boot mode 'Data area' erase bug fixed
Renesas R7F701071xxFP [LQFP144], verifying Device Settings bug fixed
New software - Version 3.72
