Added adapter: BGA-Bottom-412 + BGA-Top-406 ZIF-CS
Added adapter: BGA-Bottom-537
Added adapter: DIL24/BGA24-2.02 ZIF HFlash-1
Added adapter: DIL48/BGA100-1.02 ZIF eMMC-2
Added adapter: DIL48/BGA121-4 ZIF CY-3
Added adapter: DIL48/DSBGA40-1 ZIF-CS MSP430-1
Added adapter: DIL48/module ZIF BT-1
Added adapter: DIL48/PQFN41 ZIF IMM-1
Added adapter: DIL48/QFN24-1.02 ZIF IS31-1
Added adapter: DIL48/QFN40-1.02 ZIF LT-3
Added adapter: DIL48/QFN40-1.02 ZIF TPS40-2
Added adapter: DIL48/QFN40-2.02 ZIF ISL-5
Added adapter: DIL48/QFN56-2.02 ZIF ZL3-1
Added adapter: DIL48/QFP100 ZIF STM32L5-1
Added adapter: DIL48/QFP100-1 ZIF NEC-9
Added adapter: DIL48/QFP64-1.02 ZIF R7FA-2
Epson S1C17611 [QFP12-48], Erase procedure modified
Infineon SAF-XE164H-96Fxxx [LQFP100], IDcheck procedure modified
Macronix MX25U51245GXD [TFBGA24] (Quad I/O), alternative programming adapter DIL8/BGA24-2 ZIF SFlash-1b acceptance added
Micron MT35XU01GBBA1G12 [T-PBGA24] (Octa I/O), power up sequence improved
Micron MTFC8GAMALBH [TFBGA153], added programming options for Extended CSD register
Renesas R7F701442xxFB [LQFP176], R7F701400 [LQFP100], programming procedure for DFM improved
Atmel/Microchip ATSAMC21J18A [WLCSP56], ID check error bug fixed
Micron MT35XU01GBBA1G12 [T-PBGA24] (Octa I/O), verify error fixed
Renesas R5F72543RKBGV [BGA272], Boot mode 'Data area' erase bug fixed
Renesas R7F701071xxFP [LQFP144], verifying Device Settings bug fixed
New software - Version 3.72
