Version 3.89 features the following amendments:
PG4UW, PG4UWMC, added new type of checksum "dWord sum LE (x32), dWord sum BE (x32)"
Added module: AP1 QFP64-1.02 ZIF R7FA-3
Adesto Techn. AT25xxx, in package SOIC8 150mil, added support
ARTERY AT32, load/save file formats restricted to intelHEX (*.HEX), motorolaHEX (*.MOT) and raw birany (*.BIN); added support of all memory areas for motorolaHEX
Atmel/Microchip AT24C256C, communication speed decreased
Atmel/Microchip ATSAMD20 series, according change in datasheet the default value of WDT Window changed
Cypress CY37064 (ISP), CY37064V (ISP), JTAGen pin info removed
Dallas/Maxim DS2506 in ZIF, Communication signal handling slightly modified
Dialog Semicond. AT25xxx, in package SOIC8 150mil, added support
Discontinued module AP1 SOIC8 ZIF 150mil SFlash-1
Fidelix FM25Mxxx, in package SOIC8 150mil, added support
GEEHY APM32, load/save file formats restricted to intelHEX (*.HEX), motorolaHEX (*.MOT) and raw birany (*.BIN), added support of all memory areas for motorolaHEX
GigaDevice GD32, load/save file formats restricted to intelHEX (*.HEX), motorolaHEX (*.MOT) and raw birany (*.BIN), added support of all memory areas for motorolaHEX
Infineon XDPE15284D [QFN40] (Config), XDPE152C4D [QFN48] (Config), programming procedure improved
Macronix MX25L/Uxxx, KH25Lxxx, in package SOIC8 150mil, added support
Macronix MX25Uxxx, MX25Vxxx, MX25Lxxx, MX25Rxxx in package USON8 4mm x 3mm, added support
Macronix MX35UF1GE4AC [WSON8] and MX35UF2GE4AC [WSON8], device features support updated according to actual datasheet (removed NOR4BADD mode, added Continuous read mode, added Bad block Management Function)
Microchip PIC16F628A, communication improved
Microchip PIC16F18026, added support
Micron M25Pxxx, N25Qxxx, in package USON8 4mm x 3mm, added support
Micron MT25QL128ABA8E [SO16W] (Quad I/O), programming improved
MindMotion MM32, load/save file formats restricted to intelHEX (*.HEX), motorolaHEX (*.MOT) and raw birany (*.BIN); added support of all memory areas for motorolaHEX
NEC/Renesas uPD70F3572GB, programming procedure speed-up
Nordic nRF52xx, modified location for save DEVICEID and DEVICEADDR to CSV file
Numonyx M25Pxxx, N25Qxxx, in package USON8 4mm x 3mm, added support
Puya Semiconductor P25Qxxx, PY25Qxxx, P25Dxxx, P25Txxx, P25Rxxx, in package SOIC8 150mil, added support
Renesas R5F566Txxxxx [Boot mode], access to MDE register modified
Renesas R5F566Txxxxx, verifying Option area in boot mode modified
Renesas R7F701649xxFP, added programming OPBT2-7
Renesas R7F701649, added programming OPBT8-12 bytes
Renesas R7FA6M2AxxxFB, communication speed settings added
Spansion S29WS256NxxBFx01 [FBGA84], read operations modified
STMicroelectronics SPC584Bxxxx, device info modified
STMicroelectronics STM32, load/save file formats restricted to intelHEX (*.HEX), motorolaHEX (*.MOT) and raw birany (*.BIN), added support of all memory areas for motorolaHEX
STMicroelectronics STM32G0xx devices, option bytes erase algorithm modified
STMicroelectronics STM32H757, missing mass erase option added
STMicroelectronics STM32H7xx, access to secondary CPU algorithms modified
TI (TMS) CC13x4, CC26x4, programming CCFG registers improved
TI (TMS) CC13xx, CC26xx, erase procedure improved
TI (TMS) MSP430FR2476, programming procedure improved
Winbond W25Q64JWxxxQ [SOIC8-200], added support
Wisekey VaultIC292 [UDFN8], enhancement of error management
Atmel/Microchip ATSAMDA1 series, default value of BOD33 Hysteresis fixed
Dallas/Maxim DS2502/DS2505/DS2506 (ISP), Unexpected error 1 [IEC:4, D:3D] bug fixed
Dallas/Maxim DS2505 in ZIF, Read bug fixed
eMMC devices, "Read operation with automatic programming parameters setting" bug fixed
Microchip PIC24FJ512GU410, Unexpected error 1 [IEC:1, D:12]! bug fixed
Microchip PIC32MMxxx (ISP-2wire JTAG)/(ISP-2wire JTAG-ext.VDD), programming procedure fixed
Micronas HAL3900, opening the blank "View/Edit content of registers" bug fixed
Module AP1 SOIC8 ZIF 150mil SFlash-1b, Automatic yes bug fixed
NAND flash devices, fixed Programming error event processing in OTP area
NEC/Renesas uPD70F3610, Communication problem fixed
Realtek RTL8721DFL [QFN56], programming procedure bug fixed
Renesas R5F566TKAxFP [LFQFP100] Boot mode, buffer size bug fixed
Renesas R7FA4M2AxxxFM, power-up bug fixed
New software - Version 3.89
