Hello !
With tool "PG4UW cmd.exe " is it possible to create a script to save in a file ( format bin) a contents of memory (eprom) dump... I search a command like "savefile" .
Best regards
PG4UW cmd.exe to save a file
Re: PG4UW cmd.exe to save a file
Hello FREDC,
Unfortunately it is not possible to save out the buffer content to a HEX or BIN file when using the command line interface. However there is the following command when using the remotelb.dll interface:
function SEND_CMD_SaveFile(filename: PChar;
fileformat: integer;
timeout: integer): integer; stdcall;
This function is used to write buffer content of remote client (Pg4uw) to specified file at specified file
format.
More information can be found in the C:\Program Files\Dataman\Dataman-Pro\remotectrl\remotemanual.pdf document.
I hope this helps.
format.
I hope this helps.
Users browsing this forum: Methrennal and 11 guests
