New software - Version 3.61
Posted: 14 Sep 2020 15:33
Added adapter: DIL48/QFN32 ZIF Z8F-1
Added adapter: DIL48/QFN40-1.02 ZIF LT-1
Added adapter: DIL48/WLCSP25-4 ZIF-CS CY-1
DIL48/QFP100-1.02 ZIF xPC5x-1, AutoYes pins list correction
DIL48/LQFP64 ZIF xPC5x-2, AutoYes pins list correction
