Version 2.79 features the following amendments:
CheckSum x8, x16, fixed bug related to "Excluded blocks" feature
File format offering in dialog window SAVE FILE improved
Fixed user break of buffer allocation for recently selected device does not fire closing of application
Fixed unwanted closing of application when a time-consuming buffer operation (buffer allocation, checksum calculation, ...) was breaked by user
Fixed problem with timeout and programmer communication error when user kept caught by mouse Automatic YES! window for more than 4 seconds
Improved statistic setting during sites connecting for Pg4uwMC control SW
Working with INI file bug fixed
Atmel ATmega406, programming stability improved, code optimized
Atmel ATtiny45/85/V, programming module and adapter changed
Atmel ATtiny48/88/168, power-up sequence improved
Chingis PM25LDxxx (DualSPI), read/verify procedure improved
Freescale Semic. MC908QY, QC, verify trim value with buffer option added
Freescale Semic. MC9S12XSxx, algorithm power-off timing improvement
ISSI IS93C56A, programming procedure improved
Lattice LCMXOxxx [csBGA132], programming parameters improvement
Microchip PIC16C773, PICMicro checksum calculation added
Microchip PIC16F1xxx, set of configuration bits improved
Microchip PIC18F14K22 (ISP), PIC18LF14K22, size of program memory improved
Microchip PIC18F1xK50, fix setting default values of configuration word
Microchip PIC18F2x10/2x20/2x21/4x10/4x20/4x21, added support of preserve EEPROM memory
Numonyx JS28F128M29EWH [TSOP56], ID check improved
Numonyx JS28F256M29EWH [TSOP56], erase procedure improved
NXP/Philips LPC11xx, LPC13xx (ISP), speed up of programming algorithm
NXP/Philips LPC17xx (ISP), speed up of programming algorithm
PCT PCT25VF032B, power-up sequence improved
Renesas R5G0C314DA/DB, programming speed increased
Spansion S25FLxxxK, Programming Security Registers improved
Spansion S29GL128PxxTxx01 [TSOP56]x16, power-up modified
STMicroelectronics STM32F1xx devices with max. 48 pins support changed - specialized programming adapters introduced
TI (TMS) LM3S817-C2, programming procedure improved
Xilinx XC17xxL [VQFP44], adding of improving action stability information
NAND flash devices, Group Define file support added
Programming adapter DIL8/QFN8-4 ZIF-CS SFlash-1, 'Automatic YES!' improved
Atmel AT89LP51, AT89LP3240, bug in programming operation fixed
Atmel ATmega3290A/PA, ATmega6490A/PA, ID bug fixed
Atmel ATtiny24/44/84/A (ISP), ISP pins description bug fixed
Atmel AVR32, programming the fuses bug fixed
AUO AUO-G1422.2H, programming bug fixed
Fremont FT24C32A, programming bug fixed
Lattice ispPAC-POWR607, ID check error bug fixed, improved action stability
Microchip PIC16F1946, PIC16F1947 in TQFP64, programming procedure bug fixed
Microchip PIC16F505, PIC16F526, insertion test bug fixed for package QFN16 3x3
Microchip PIC17C44, verification procedure bug fixed
Microchip PIC18F13K50, PIC18F14K50, verification procedure of configuration word Config2L bug fixed
Microchip PIC18F14K50, programming procedure bug fixed
Microchip PIC18F2xK2x [UQFN28], PIC18LF2xK2x [UQFN28], insertion test procedure bug fixed
Samsung S3F828B (ISP), "Voltage out of range" (Vcc check) bug fixed
Siemens/Infineon SAB-C501G-1E, device size bug fixed
SST SST49LF008A [PLCC32], access violation bug fixed
Custom NAND flash algorithm LEX-01, some bugs removed
Unspecified MMC-2GB, problem with cancel of buffer allocation process fixed
Xilinx XC17S200A/300A [VQFP44], insertion test bug fixed
New software - Version 2.79
