Version 2.39 features the following amendments:
Atmel AT45DB021D ID check error fixed, device programming improved
Atmel AT45DB321C, Device ID check bug fixed and Device Verify bug fixed
Chipcon CC243x, CC1110, Philips PCD807xx, insertion test bug fixed
Hynix HY29LV320B/T [TSOP48], insertion test bug fixed
Infineon SAx-C164CI-8E, read procedure modified
Lattice LC4064ZC [csBGA56], [csBGA132], programming parameters assignment bug fixed
Microchip PIC24FJ64GA008, cfg bits programming bug fixed
Microchip dsPIC33FJ, PIC24FJ in TQFP100 package insertion test bug fixed
Microchip PIC16F648A, verification bug fixed
Microchip PIC18F2480/2580/4480/4580, boot block size bug fixed
Motorola MC68HC05B6, Erase bug fixed
Renesas M30624FGAFP, programming protection register bug fixed
Seiko Instruments S-93C76A, programming bug fixed
Xilinx XC2C32/32A/64/64A [CP56], programming parameters assignment improved
Zilog Z8FMC16100, fixed bug in option bit setting
Main Flash and special/security/HiROM block programming spitted for Flash memories which aren't yet implemented
Altera EPC1/1441, mode of CRC calculation (regarding invalid bits) can be determined by setting of a parameter
Altera EPCSxx, added Device ID check
Altera EPM240/24G/570/570G/1270/1270G/2210/2210G, improving of checksum calculation, adding checksum result for CFM block only
Altera EPM1270 [FBGA256], increasing of overcurrent protection limits
Cypress CY37064 [TQFP100], increasing of overcurrent protection settings
Cypress CY39xxx, CYP25xxx, CYS25xx (ISP), improving of General info
Cypress CY8C2xxxx series, reading checksum from Cypress Intel HEX file modified
Cypress CY7C63803, security bits programming improved
Cypress CY8C21534, ID check improved
Eon Silicon Dev. EN29LV160Axx, programming improvement
Lattice ispPACPOWRxxx (ISP), improving of General info
Lattice LC4xxx [FPBGA256], increasing of overcurrent protection limits
Macronix MX29LV640Mx, programming speed increased
Microchip PIC12C671 and PIC16F/LF777, power-up sequence improved
Microchip PIC18F/LF8490, VCCmax verification improvement
Microchip PIC24FJ, PIC24HJ and dsPIC33FJ series programming speed increased
Motorola/Freescale MC68XXX705J1A, MC68XXXKJ1: support at USB added
NS COP8CxR, COP8SxR, separated algo for chips datecode before 0318 and chips datacode 0318 and after
Samsung K5E5658(A/H)CM, insertion test bug fixed
SGS-Thomson (STM) M25Pxx, added Device ID check
Spansion S98WS256NE0FW001, programming improvement
SST SST49LF016C, read and programming modifications
SST SST39VF6401B, programming improved
Implementation of tolerant verification for 16-bit NAND FLASH memories
verification routine speed up for 16-bit NAND FLASH memories
Programming improvements for 16-bit NAND FLASH memories
Zilog Z8FMC16100 improved programming operation
New software - Version 2.39
