New software - Version 3.73
Postby Dataman (Daniel Smith) » 14 Jan 2022 16:15
Added adapter: DIL48/module ZIF PAN1780
Added adapter: DIL48/LQFP44 ZIF-CS R5F-1
Added adapter: DIL48/QFN32 ZIF STM32-2&GD32
Added adapter: DIL48/QFN32-2.02 ZIF M03x-1
Added adapter: DIL48/QFN40-2.02 ZIF BEK-1
Added adapter: DIL48/QFN48-1.02 ZIF LPC-1
Added adapter: DIL48/QFN48-1.02 ZIF STM32G4-1
Added adapter: DIL48/QFN48-2.02 ZIF ISL-2
Added adapter: DIL48/QFP100-1.02 ZIF-CS R5F-19
Added adapter: DIL48/QFP128-1.01 ZIF PLD-8
Added adapter: DIL48/QFP144-1.02 ZIF R7FS-1
Added adapter: DIL48/QFP176 ZIF STM32-3
Added adapter: DIL48/QFP176 ZIF STM32-3&GD32
Added adapter: DIL48/QFP52-2.05 ZIF-CS ST62-1
Added adapter: DIL8/QFN8-5.02 ZIF SFlash-1b
Macronix MX25U25645G [SOP16] (Quad I/O), added support with adapter DIL16W/SOIC16 ZIF 300mil SFlash-1b
Micron MT25QU256ABA8E [SO16W] (Quad I/O), added support with adapter DIL16W/SOIC16 ZIF 300mil SFlash-1b
Users browsing this forum: No registered users and 29 guests
