MX 27C4096DC-10
MX 27C4096DC-10
Hello, can someone help me find the working project for a MX 27C4096DC-10 on the S6? I can't find a working project to read/write. Thank you
Re: MX 27C4096DC-10
Hello mektrix5000,
The MX 27C4096DC-10 device is not currently supported on the Dataman-S6. Our engineers have located the programming specification and are working to implement the programming support, as soon as it is available I will post the download link here.
Re: MX 27C4096DC-10
Thanks Neil! Appreciate how quickly you guys get these updated
Re: MX 27C4096DC-10
Updated database adding support for the MX 27C4096DC-10 device is now available to download:
https://www.dataman.com/mwdownloads/dow ... nk/id/228/
Re: MX 27C4096DC-10
[2021 / 08 / 01 - 11:45:01] SN Read
[2021 / 08 / 01 - 11:45:01] SN Read Done
[2021 / 08 / 01 - 11:45:02] Detect Dataman-S6 Compact USB Programmer
[2021 / 08 / 01 - 11:45:02] Firmware Number Get
[2021 / 08 / 01 - 11:45:02] Firmware Number = 1
[2021 / 08 / 01 - 11:45:02] Firmware Number Get Done
[2021 / 08 / 01 - 11:45:02] Firmware Version Get
[2021 / 08 / 01 - 11:45:02] Firmware Version = 1.9G
[2021 / 08 / 01 - 11:45:02] Firmware Version Get Done
[2021 / 08 / 01 - 11:45:02] No Updates Are Required
[2021 / 08 / 01 - 11:45:02] Hardware Init Setting
[2021 / 08 / 01 - 11:45:02] Hardware Init Setting Done
[2021 / 08 / 01 - 11:45:02] Driver INI Setting
[2021 / 08 / 01 - 11:45:02] Driver INI Setting Done
[2021 / 08 / 01 - 11:45:02] Check CRC32 of Driver
[2021 / 08 / 01 - 11:45:02] Check CRC32 of Driver Done
[2021 / 08 / 01 - 11:45:02] FPGA Init
[2021 / 08 / 01 - 11:45:03] FPGA Init Done
[2021 / 08 / 01 - 11:45:03] Device Select = MXIC - MX27C4096(DIP40)
[2021 / 08 / 01 - 11:45:03] <Note>================================================
[2021 / 08 / 01 - 11:45:18] Insert Detect
[2021 / 08 / 01 - 11:45:18] Pin 1 of IC is Fail!
[2021 / 08 / 01 - 11:45:18] Pin 2 of IC is Fail!
[2021 / 08 / 01 - 11:45:18] Pin 11 of IC is Fail!
[2021 / 08 / 01 - 11:45:18] Pin 20 of IC is Fail!
[2021 / 08 / 01 - 11:45:18] Pin 22 of IC is Fail!
[2021 / 08 / 01 - 11:45:18] Pin 23 of IC is Fail!
[2021 / 08 / 01 - 11:45:18] Pin 24 of IC is Fail!
[2021 / 08 / 01 - 11:45:18] Pin 25 of IC is Fail!
[2021 / 08 / 01 - 11:45:18] Pin 26 of IC is Fail!
[2021 / 08 / 01 - 11:45:18] Pin 27 of IC is Fail!
[2021 / 08 / 01 - 11:45:18] Pin 28 of IC is Fail!
[2021 / 08 / 01 - 11:45:18] Pin 29 of IC is Fail!
[2021 / 08 / 01 - 11:45:18] Pin 30 of IC is Fail!
[2021 / 08 / 01 - 11:45:18] Pin 31 of IC is Fail!
[2021 / 08 / 01 - 11:45:18] Pin 32 of IC is Fail!
[2021 / 08 / 01 - 11:45:18] Pin 33 of IC is Fail!
[2021 / 08 / 01 - 11:45:18] Pin 34 of IC is Fail!
[2021 / 08 / 01 - 11:45:18] Pin 35 of IC is Fail!
[2021 / 08 / 01 - 11:45:18] Pin 36 of IC is Fail!
[2021 / 08 / 01 - 11:45:18] Pin 37 of IC is Fail!
[2021 / 08 / 01 - 11:45:18] Pin 38 of IC is Fail!
[2021 / 08 / 01 - 11:45:18] Pin 39 of IC is Fail!
[2021 / 08 / 01 - 11:45:18] PinScan = 0x59FE000003F800
[2021 / 08 / 01 - 11:45:18] Insert Detect Fail!
Hmm not working, tried two eproms. MX 27C4096DC-10 1B6273 VPP=12.5V
Thanks Neil
Thanks Neil
Re: MX 27C4096DC-10
We have modified the programming algorithm, we hope that it will improve the situation.
Please download the updated software from our website here:
Re: MX 27C4096DC-10
Looks like that fixed it, thanks Neil!We have modified the programming algorithm, we hope that it will improve the situation.
