New software - Version 3.52
Posted: 24 Sep 2019 15:50
Added module: AP1 BGA50-1 ZIF nRF-4
Added module: AP1 LQFP80-2 ZIF R5F-2
Added module: AP1 QFN24-1.02 ZIF NHS-1
Added module: AP1 QFN40-2.02 ZIF MP-1
Added module: AP1 QFN40-1.02 ZIF R5F-2
Added module: AP1 QFN40-2.02 ZIF TPS53-2
