PG4UW Minor Softare Bug?
andyrichmond
Postby andyrichmond » 15 Apr 2016 10:06
Hello Dataman,
Thought I'd just post this minor bug? that I've seen in the latest PG4UW software v3.23/04.2016.
When I use the "Fill Block" menu item from the "Buffer" dropdown menu and I fill any valid memory location(s) with any value and then I look at the memory window via the "View/Edit" menu item the wrong memory locataion(s) is/are highlighted in green.
I've notice this on several microchip PIC devices so I assume its a generic problem.
I'm using the PikPro programmer in Windows 7 Professional service pack 1.
Andy
Re: PG4UW Minor Softare Bug?
Postby Dataman (Neil Parker) » 15 Apr 2016 10:13
Hello Andy,
Thank you for your report. I have been able to recreate the situation as described and I have made our software engineers aware of it.
As soon as I hear back from them, I will post an update here.
andyrichmond
Postby andyrichmond » 15 Apr 2016 10:22
Hi Neil,
Thanks for the prompt reply.
Cheers,
Andy
Postby Dataman (Neil Parker) » 26 Apr 2016 13:11
Hi Andy,
We have fixed the correct address range for highlighting of changed buffer blocks in the View/Edit buffer window after using the operation "Fill buffer block" (with pattern string) and when the current buffer view mode is x16.
URL: http://www.dataman.com/downloads/dl/fil ... ftware.zip
Version: 3.23h/04.2016
andyrichmond
Postby andyrichmond » 05 May 2016 08:08
Hi Neil,
Thanks a lot :D
Andy
