New software - Version 2.58
Postby Dataman (Daniel Smith) » 15 Nov 2011 12:01
Version 2.58 features the following amendments:
Samsung K9LAG08U0A [TSOP48], ID check bug fixed
Spansion S71GL128NxxBxx9, insertion test bug fixed
Sharp LHF00L31, LHF00L30, LHF00L29, LHF00L28, LHF00L25, LHF00L24, wrong buffer size fixed
Macronix MX25L8025 [SON8], removed from support
Xicor X5083, programming bug fixed
Maxim MAX9669, Device overcurrent error fixed
Atmel ATmega640, device ID bug fixed
Micron MT29F4G08AACWC [TSOP48], insertion test bug fixed
Intel PF38F4060M0Y3DE, PF38F5060M0Y3DF, algorithm initialization bug fixed
Silicon Laborat. C8051F300, programming/erase bug fixed
Fixed internal error related to 9S12XExxxx LQFP112 algorithms
Atmel ATmega162,ATmega32U4, ISP pin numbering bug fixed
Microchip PIC18FxxKxx, power-up procedure bug fixed
Microchip PIC24Hj Family, power-up procedure bug fixed and load User ID from hex file
Fixed Config register programming of MC68HC11Ax, related to USB only
Numonyx, STMicroelectronics M29W008DB/DT [TSOP40], sectors unprotect bug fixed
PMC PM25LV family, programming bug fixed
TI (TMS) MSP430F241x devices, default setting "Preserve TLV structure" bug fixed
STMicroelectronics M48T59, size of RTC area bug fixed
Nordic Semiconductor nRF24LU1 [QFN32], insertion test bug fixed
Sharp LH28F640BFHG-PBTLE7 [CSP48], wrong information about suitable converter fixed
STMicroelectronics STM8AF51AAT (ISP), verify procedure bug fixed
ST Microelectronics STM32F101T6xxA [VFQFPN36], pins assignment bug fixed in Device Info window recommendations
TI (TMS) MSP430Fxxxx with TLV structure, default setting "Preserve TLV structure" bug fixed
Numonyx M29WxxxD, M29WxxxE, unprotect procedure bug fixed
Microchip dsPIC33FJ128MC802, configuration fuses bug fixed
Microchip dsPIC33FJ16GS504, pin assignment and configuration fuses bug fixed
Microchip PIC18F13K50, erase ID Location bug fixed
Microchip PIC16F876, PIC16F877, load hex file bug fixed
Xilinx XC95144 [PQFP100], changing of overcurrent protection parameters
Samsung K8S6415ETx [FBGA44], K8S6415EBx [FBGA44], package details info in CTRL+F1 window improved
Samsung K8S2815ETx [FBGA44], K8S2815EBx [FBGA44], package details info in CTRL+F1 window improved
Xicor X2864A, programming algorithm improvement
STMicroelectronics M59PW1282, erase modified
NAND01GW3B2BN [TSOP48] (LGE-03) and NAND02GW3B2DN [TSOP48] (LGE-04), changes regarding to additional requirements of the client
NEC uPD27C64, programming algorithm improvement
Xilinx XCFxxS/P, XC18Vxx (ISP), adding of Load FPGA feature for initializing of FPGA after programming of configuration device
Lattice ispLSI2032/A [TQFP48], improving of device pin assign
Chingis Pm25LV512A [TSSOP8], extended page program time
EON EN29SL160, programming modified
Micron MT29F1G08ABBHC-ET [VFBGA63], operation speed performance increased
Microchip 37LVxxx, improving of pgm. parameters assignment
Zilog ZLF645xxxxxxx, power-up sequence modified
Renesas M30625FGPGP, programming improved
Freescale/Motorola MC56F8335 [LQFP128], S-format file load adjustments, now fits to CW compiler
Atmel AT32UC3B0256, erase function improved
Freescale/Motorola MC9S08GTxx, algorithm stability improvement
Winbond W25X32V, change of item name in <Alt+S> from "WPEN" on "SRP"
Silicon Laborat. C8051T61x/T63x programming algorithm improved
Silicon Laborat. C8051F0xx algorithm improvement
Nordic Semiconductor nRF24LU1, nRF24LE1, algorithm improvement
Silicon Laborat. C8051F00x/C8051F01x, power-up sequence modified
Xilinx XC3S50AN, improving of pgm. parameters assignment
Xilinx XC95288XL/XV [FBGA256], improving of insertion test
Micron MT29F4G08AACWC [TSOP48], insertion test bug removed, operation stability improved
Silicon Laborat. C8051F341, improving of device pin assign
Silicon Laborat. C8051F34x, power-up sequence modified
SST SST34HF162G, SST34HF164G, package details info in CTRL+F1 window improved
Microchip PIC16F59 (ISP), added support for PikProg2 and SmartProg2 programmers
Microchip PIC18Fxxx, PIC18FxxJxx, PIC24FJxx, PIC24HJxx Family, PICmicro checksum calculation added
Changing the two-lines error messages for NAND flash, OneNAND, STR7xx, STR91x and STM32F10x devices. As pg4uwmc's log-window shows only the first line of site's info-window, error messages was not readable (only the text "Access with selected device - error!" was displayed). Now, all messages are single-line only.
change at buffer edit for devices TBP24SA10N and TBP24S10N, (It can only to be edited 4 down bits)
Improving of converter name AS-100-28-01Q; Emulation Technology
DIL48/QFP32-1 ZIF STM8-1, converter support improvement
DIL48/QFP48 ZIF PLD-1, improving of converter power-up routine
