New software - Version 3.42
Postby Dataman (Daniel Smith) » 12 Jul 2018 13:32
Added module: AP1 BGA256-0491/0453
Added module: AP1 BGA256-0678/0453
Added module: AP1 BGA332-1 ZIF PLD-1
Added module: AP1 BGA484-1 ZIF PLD-9
Added module: AP1 QFN48-1.02 ZIF EFM-1
Added module: AP1 QFP100-1 ZIF NEC-11
Added module: AP1 TSOP32 ZIF 12.4mm NOR-2
Added module: AP1 TSSOP10-170 ZIF R5F-1
Winbond W25Q64FWxxxQ [SOIC8] (QuadSPI), added support
AP1 QFP32-1 ZIF STM8-1, bug fixed
