http://www.drivestar.biz/adapter-wlpl44 ... -1420.html
specified for the XC9536 etc
using the WL-PL44-U001 dip-44 to plcc44 adaptor I get
Device code unmatched !
Ok so i bought the adaptor online and it looks great.
Do you have a list showing how the pins should be mapped so I can verify the adaptor is right?
xc9536xl
Re: xc9536xl
Hello chrisautosound,
The adaptor connection tables for the most popular sockets can be found on our website here: http://www.dataman.com/dataman-48xp48uxp-resources
If you have any further questions, please let me know.
chrisautosound
Re: xc9536xl
thanks for the tip, I ohmed out the adaptor and it is straight 1 to 1, UNIV-44
but same failed result for all actions
read
blank check
program etc
read
blank check
program etc
Re: xc9536xl
Did the error message in the log window specify the expected Device ID and the ID as read from the device?
If you can provide all the codes from the top of the device we can check with Xilinx to see if they have changed the Device ID value on later devices.
chrisautosound
Re: xc9536xl
No, it does not. The only message is Device code unmatched !
there are no bottom markings
top markings
XC9536XL
PC44CMN0401
F1291492A
10C
Chips supplied by Harman. Insert in socket.
Then select the IC, then load the 770498.jed file supplied by Harman.
blank test fails Device code unmatched !
program fails Device code unmatched !
so far I have used the succesfully use the 48LV for 27C eeproms and 18vc8 devices.
Thanks for the help, let me know what you find. chris
top markings
XC9536XL
PC44CMN0401
F1291492A
10C
chrisautosound
Re: xc9536xl
HMM I dont think it is the PLCC-> DIP adaptor.
I ordered a PLCC44 device for checking the adaptor and my 48LV
With the AT271024 in place there are no errors and the blank check works.
any news on your end?
Chris
Chris
Re: xc9536xl
Hello Chris,
I am afraid that we cannot offer a solution for this device. It may be a new version of the chip which is incompatible with the existing algorithm.
We have contacted Xilinx and requested updated information on the chip but we were informed that it is an old algorithm and chip and that Xilinx do not have the resources to continue supporting it any more.
I can only recommend that you contact Xilinx and ask for their recommended programming solution.
I regret that we could not be of more help on this occasion.
