I've been asked to help with a Motorola MC68705R3CS. I've got a 48XP which I've not used for a very long time. I now longer have my PC with a parallel port but I have an old Vista laptop which should run the software. Can anyone recommend a USB to parallel port adapter which would work for my setup?
Thanks.
USB-parallel cable for 48XP
Re: USB-parallel cable for 48XP
Hello tantalum61,
The Dataman-48XP programmer uses the parallel port in a slightly non-standard way. This means that the programmer will only work over a parallel port that is part of the PC/laptop motherboard. We have not found any USB-to-parallel, PCI/PCI express-to-parallel solution that works with this programmer.
As the UXP upgrade kit (adds a USB port) for this programmer is no longer available the only option is to locate a pc/laptop with a built in parallel port.
If you are looking for a replacement programmer with USB support and OS support from Windows XP to Windows 11, then I would recommend considering the Dataman-48Pro2 universal programmer.
Here is a little bit about the 48Pro2 programmer:
I believe the Dataman 48Pro2 to be the best in its class on the market worldwide at the moment. The Dataman 48Pro2 offers super-fast programming speeds and includes advanced features such as ISP capability, USB 2.0 interface and comprehensive software compatible with Windows XP, Server 2003, Vista, 7, 8, 10 and 11. The Dataman 48Pro2 supports over 132,000 devices which is updated every 3 - 4 weeks with each update adding 200 - 300 new chips. Support can be added for missing devices quickly and typically free of charge.
You can download and run the control software for this programmer. It will run unrestricted in DEMO mode allowing you get a feel for the interface, select your chip, and load your programming data into the buffer.
The programmer comes as standard with our 3-year parts and labour warranty, free life-time technical support, and software updates.
The 48Pro2 is available from stock ready for dispatch upon receipt of payment.
If you have any questions, please do not hesitate to contact us.
tantalum61
Hi Neil,
Thank you for the quick and detailed reply. It's not the answer I was hoping for but at least I won't waste time trying cables that wont work. As I'm try to help a friend out as a favor I think my best option is to get an old PC with a parallel port.
Cheer.
Cheer.
tantalum61
Hi Neil,
I'm back in business, I forgot I've got an old Win2000 laptop with a parallel port. I've installed the software and it runs ok.... but...
The "blank" check runs ok and identifies my chip isn't blank but the "read" button is greyed out, could you give me any advice? Many thanks.
Hello tantalum61,
What is the part name of the device you are working with?
tantalum61
Hi Neil, it's a Motorola MC68705R3CS.
Hello tantalum61,
The Motorola MC68705R3CS chip cannot be read by design, therefore the read operation is not available (not supported by our programmers).
tantalum61
Hi Neil,
Once again thank you for the quick, informative response.
That's a real shame the chip can't be read but at least I now know and won't waste anymore time on it.
And I've now got my 48XP up and running.... I just need to find something to do with it!
Andy.
Andy.
