Here are my results, it still fails:
L0114: >> 19.04.2007, 16:26:13
L0115: ------------------------------------
L0116: ==== Device operation options ====
L0117: ------------------------------------
L0118: - Addresses
L0119: Split: None
L0120: - Insertion test
L0121: Insertion test: Enable
L0122: Device ID check: Enable
L0123: - Command execution
L0124: Erase before programming: Enable
L0125: Blank check before programming: Enable
L0126: Verify after reading: Enable
L0127: Verify: Once
L0128: - Programming parameters
L0129: [x] Flash
L0130: [ ] User Protection register
L0131:
L0132: >> 19.04.2007, 16:26:16
L0133: Programming device: Intel JS28F128P33B [TSOP56].
L0134: Buffer checksum in range of device [0h..7FFFFFh]: B0BB876Eh
L0135: Device insertion test ...
L0136: Checking device ID ...
L0137: Erasing device ...
L0138: Device blank checking ...
L0139: Programming Flash ...
L0140: Programming Flash - error!
L0141: ADR=5DFh, DO=CAD8h,DI=FFFFh, ST=0h
L0142: Elapsed time: 0:02:05.5
Darrell
Problem with 48Pro...Help please
Re: Problem with 48Pro...Help please
This time I filled the buffer with random data and it still failed.
L0144: >> 19.04.2007, 16:30:22
L0145: Reading device: Intel JS28F128P33B [TSOP56].
L0146: Device insertion test ...
L0147: Checking device ID ...
L0148: Reading Protection register ...
L0149: Reading device ...
L0150: Verifying device with buffer ...
L0151: Reading device - done.
L0152: Elapsed time: 0:00:46.0
L0153: Buffer checksum in range of device [0h..7FFFFFh]: FEF98440h
L0154: Buffer "Checksum operation" time elapsed: 938 ms
L0155: Buffer "Random Fill operation" time elapsed: 1032 ms
L0156:
L0157: Buffer is filled with random data.
L0158: Buffer "Checksum operation" time elapsed: 1016 ms
L0159:
L0160: >> 19.04.2007, 16:32:18
L0161: Buffer checksum in range of [0h..7FFFFFh]: 7F7C76B8h
L0162:
L0163: >> 19.04.2007, 16:32:33
L0164: Programming device: Intel JS28F128P33B [TSOP56].
L0165: Buffer checksum in range of device [0h..7FFFFFh]: 7F7C76B8h
L0166: Device insertion test ...
L0167: Checking device ID ...
L0168: Erasing device ...
L0169: Device blank checking ...
L0170: Programming Flash ...
L0171: Programming Flash - error!
L0172: ADR=32BFh, DO=FFC9h,DI=3F0Fh, ST=0h
L0173: Elapsed time: 0:02:06.2
Darrell
L0156:
L0159:
L0162:
Darrell
Still fails with a different data code Intel chip... not having fun anymore...
Darrell
Darrell
Hi Darrell,
Sorry for the delay on this but it took longer than expected. The second batch of chips we sourced behave differently from the ones we had initially.
We are confident we have fixed the problem now.
Please download, install and use latest OnDemand software:
URL: http://www.dataman.com/temp/237h_pg4uward.zip
Version: 2.37h/05.2007 (03.5.2007)
sorry for the delay, yes the update worked, thought I would let everyone know.
btw, lost my password... doh!
Darrell2
Darrell2
