New software - Version 2.50
Posted: 27 Nov 2011 12:47
Version 2.50 features the following amendments:
Renesas M30291F8HP: erasing bug fixed
Microchip PIC17C766 [PLCC84], power-up procedure bug fixed
NEC uPD78F0034A, synchronization procedure bug fixed
Buffer checksum in range of device for x16 organization bug fixed
Renesas M30291F8HP, verification bug fixed
Motorola/Freescale Semic. HCS08 and RS08, ISP algorithm bug fixed
Motorola/Freescale Semic. MC56F8345 [LQFP128], insertion test bug fixed
Numonyx M29W128GHxxN, programming bug fixed
TI (TMS) MSP430F1481, erase action bug fixed
STMicroelectronics ST72F651AR6T [LQFP64], option bytes programming bug fixed
Atmel AT25DF641 [VDFN8], reading sectors lock down status bug fixed
STMicroelectronics ST72F521R9T [TQFP64], erasing bug fixed
Cypress CY8C24123A, ID check bug fixed
Sunplus SPCP868A, location of Program ROM Space in buffer bug fixed
Sino Wealth MCU family, checksum calculating in addresses range of device bug fixed
STMicroelectronics ST72F324BK2T [TQFP32], option bytes programming bug fixed
Microchip PIC18F4685, programming of configuration bits bug fixed
Macronix MX29LV128DT/B, programming bug fixed
Macronix MX29LV128DT/B [TSOP56], insertion test bug fixed
Motorola/Freescale Semic. MC68HC705C8A, option verify error bug fixed
Freescale Semic. MC9S08, 250KHz trimming value programming bug fixed
Freescale Semic. MC68HC908QCxx, inZIF algorithms bug fixed
STMicroelectronics ST72F321BR6T, programming option bit PKG[1] bug fixed
Microchip PIC10Fxx, Blank check procedure bug fixed
Microchip PIC16F526, insertion test bug fixed
Microchip dsPIC33FJ32MC204 [QFN44], pins assign bug fixed
Microchip dsPIC33FJ128MC708 [TQFP80], insertion test bug fixed
Sunplus SPCP868A, device/buffer start bug fixed
Fujitsu MCU (MB90Fxxx) devices with Security feature, programming improved
ISSI IS93C66A (x16) [TSSOP8], reading operation improved
Microchip PIC10F202, power-up procedure improved
Altera MAX IIG/Z, power-up procedure improved
Atmel ATmega168, erase function improved
Atmel AT49BV320D, power-up and power-down procedures improved
Renesas M3087BFLGP, programming improved
Sunplus SPCP868A, programming algorithm improvement
Microchip PIC10F202, PICmicro checksum calculation added
Motorola/Freescale Semic. MC9S08, MC9RS08: another improvement of BDM communication
Samsung K5N3217, power-up and power-down sequence improved
Motorola/Freescale Semic. MC56F8345, algorithm improved
Atmel ATmega series, ATtiny series, erase function improved
Altera EPC2, MAX II, JTAG code optimization
Lattice ispMACH4000B/C/V/Z, ispMACH 5000VG, ispMACH 5000B, ispXPLD 5000MX, JTAG code optimization
Xilinx XCFxxP, JTAG code optimization
Xilinx XC95144XL/XV, XCR3128XL [CSP144], differentiation of different device packages - Flex Tape and Laminate
STMicroelectronics NAND01GW3B2AN [TSOP48], NAND01GW3B2AZA [VFBGA63], timing and identification improved
Realtek RTD2120L, programming and erasing improved
Chipcon/TI CC243x, CC11xx, CC25xx, speed-up of programming algorithm
Microchip PIC16C765, PIC16CE625, PIC16LF876A, PIC18F252, PIC18F2580, PIC18F2620, PIC18F4550, PIC18F6620, PIC18F6622, PIC18F6720, PIC18F6722, PIC18F8520, dsPIC33FJ64MC508, added checksum calculating
