New software - Version 2.51
Posted: 27 Nov 2011 12:48
Version 2.51 features the following amendments:
Excel Semiconduct. ES25P16, programming bug fixed
STMicroelectronics M36L0R8060B8, programming bug fixed
NEC uPD75P0016, uPD75P068 and uPD75P54, "SW Internal Error 1" bug fixed
Altera EPC16 [UBGA88], insertion test bug fixed
Fujitsu MCU programming bug fixed, which can cause buffer range check error
Xilinx XC3S50AN, power-up routine bug fixed
Microchip PIC16F506, power-up procedure bug fixed
TI (TMS) MSP430F149 (ISP-JTAG), erase menu bug fixed
STMicroelectronics ST72F321AR9T [TQFP64], erasing bug fixed
Samsung K9F8G08U0M, programming bug fixed
Philips/NXP P87LPC767 (ISP), CFG1,CFG2 programming bug fixed
Microchip PIC18F4320 [QFN44], programming bug fixed
Microchip PIC18F4480, configuration bits bug fixed
Microchip PIC18F4320 [QFN44], Insertion test bug fixed
Microchip PIC18F6722, PICmicro checksum calculation bug fixed
Microchip PIC16C54, programming bug fixed
Motorola/Freescale MC68HC912DG128A, EEPROM programming bug fixed
Freescale MC9S08QE128 [LQFP64], internal error bug fixed
Atmel ATmegax8xx [MLF28], insertion test bug fixed
Lattice ispPACPOWR607, insertion test bug fixed, modification of code
Atmel AT32UC3B0256, SW internal error fixed
Spansion S29GL256NxxFxxR1 [FBGA64] x16, ID-check procedure bug fixed
Microchip PIC18F2221, configuration bits bug fixed
Altera EPC8 [PQFP100 Option2], erasing bug fixed
Spansion S72NS512N, unprotect bug fixed
Atmel ATtiny series, ATmega series, erase bug fixed
Freescale Semic. MC9S08SH8, memory map bug fixed
Motorola/Freescale Semic. MC68HC912B32, algorithm instability fixed
Motorola/Freescale Semic. HCS08, algorithm bug fixed, related to certain families
Toshiba TMP88PH40N, programming bug fixed
Lattice ispPACPOWR1220AT8, insertion test bug fixed, modification of code
Microchip PIC12C508, programming procedure bug fixed
Philips P89V662 [TQFP44], P89V664 [TQFP44], size of device bug fixed
Microchip PIC18F45J10, power-up procedure bug fixed at PIKprog2 programmer
Microchip PIC18F6527, 6622, 6627, 6722, configuration bits bug fixed
Atmel AT25DF321A [SOIC8], AT25DF321A [UDFN8], reading sectors lockdown status bug fixed
SST SST49LF004A/B [TSOP32], SST49LF008A [TSOP32]/[TSOP40], speed-up of programming algorithm
Micron MT29F4G08AAAWP [TSOP48], programming voltage decreased to 2.7V
Microchip PIC10Fxxx, OSCCAL value information after programming into log window added
IDT IDT5V9885, added programming of bits on address 04h
SST SST39WF800AxxxxxB3, programming and verify procedure improved
TI(TMS) MSP430F2274 (ISP-4wire JTAG), power-up improved
Motorola/Freescale MC68HC11, automatic erase before programming added
NXP/Philips LPC2364 (ISP), LPC2366 (ISP), LPC2368 (ISP), LPC2378 (ISP), ID-check procedure improvement
STMicroelectronics M29W128G, programming improved
Microchip PIC18F4480, configuration bits programming improved
Microchip PIC16F877, PICmicro checksum calculation added
Realtek RTD2120L, programming of special area edit
Spansion S29GL128M, read and verify procedure improved
Amic A29L008, erase procedure modification
Fujitsu MB90P663, programming procedure modification
Fujitsu MB95F136, verify procedure modification
EON EN29SL400, programming procedure modification
Winbond W79E342, W79E8213, W79A9311, programming improvement
Altera EPC1, modification of power up routine
Xicor/Intersil EEPROM X28xxxx, programming algorithm improvement
STMicroelectronics STM32F10x, modification of erase procedure by pages (in accord with new programming manual (PM0042 ver.3) - page 0 is not erasable automatically
Added new feature for RBA (Reserved Block Area) mode of NAND flash devices:
a) User Area - reservoir - RBA Table (old)
b) User Area - RBA Table - reservoir (new)
Authentication of converter DIL48/QFP64 ZIF HD64-2 improved
USB driver improvement
Atmel AT32UC3Bxxxx, chip erase bug fixed and function for set of security bits improved
Atmel AT49BV160C, read and verify procedure improved
Microchip PIC10Fxxx, added check OSCCAL calibration value
Eon Silicon Dev. EN29LV160AB/T, programming improvement
Realtek RTD2120L: power-up improved
Motorola/Freescale MC68HC912DT128A (ISP), oscillator operating frequency changed
Added pins "Target system power supply" for EM6819 (ISP) device
NXP P89V660 programming procedure improved
Spansion S29GL256NxxTFxR1 [TSOP56] x16, read and verify procedure improved
Atmel ATmega8535, erase routine stabilized
Microchip dsPIC33FJ, PIC24 series, programming speed increased
Atmel AT26DF321 [SOIC8], reading stability improved
SST SST25LF020A [SOIC8], Sector Erase operation added
Renesas R5F212B8SxFA, programming speed increased
Numonyx M29W128G, programming improvement
Freescale Semic. MC9S08DZ60, added handling of EPGMOD bit
Motorola/Freescale Semic. HCS08, added write of trimming value to log window during device read
Motorola/Freescale Semic. MC68HC912Bx128A, algorithm speed up
SEEQ 2816A/H programming procedures improved
TI (TMS) MSP430F20xx (ISP-4wire JTAG), Information memory and Main memory can be programmed separately
Atmel AT32UC3Bxxxx, Programming of the fuse bits improved
Atmel AVR-32 series, Erase function improved
Zilog ZLF645xxxxxxx - improving read/programming speed
SST SST25xxx, Sector Erase operation added
ISSI IS93CxxA (x16)/(x8), reading operation improved
SST SST49LF004A/4B/8A [TSOP32], speed-up of programming algorithm
Speed-up of programming algo for some older devices in TSOP40 package: Intel TE/E28F008SA [TSOP40], SST SST49LF008A [TSOP40], AMD Am29F017D [TSOP40], STMicroelectronics M29F080A/D [TSOP40], M29F016B/D [TSOP40], M29F032D [TSOP40]
