New software - Version 2.54
Posted: 27 Nov 2011 12:49
Version 2.54 features the following amendments:
Atmel ATmega32U4 (ISP), bug with overcurrent on pin 13 fixed
Atmel ATtiny28 [MLF32], bad socket converter type bug fixed
STMicroelectronics GAL16V8AS/S, programming parameters assignment bug fixed for ID check routine and insertion test
Zilog ZLP32300xxxxx, device programming bug fixed
Motorola/Freescale Semic. HC908, algorithm bug fixed Freescale Semic. MC9S08SH16/32, algorithm instability fixed
Renesas M3062LFGPFP, power-up sequence modification
Samsung K9F8G08U0M, read/verify procedures modification
Microchip PIC16F872, power-up procedure modification
STMicroelectronics ST62T65C, option bytes verify modification
Atmel ATmega324PA, ID code bug fixed
Samsung K5D1213ACE [FBGA137] (IAC-01), project compatibility problem removed
Motorola/Freescale Semic. HC908 ISP, fixed supply voltage connection bug
Motorola/Freescale Semic. HCS08, fixed instability of algorithm
AMD AM29BDD160G, "Internal Error" bug fixed
Atmel AT91SAM7S32 [LQFP48], algorithm bug fixed
Microchip PIC24HJ64GP202, ID code bug fixed
Freescale MCF52210 (ISP), device size bug fixed
Intel DE28F800F3 [SSOP56], read, verify and blank check procedures improved
Xilinx XC95288 [HQFP208], increasing of overcurrent protection limits
Freescale Semic. MCF5216 [MAPBGA256], algorithm stability improvement
Motorola (ON Semi) MCM68764, programming algo improved
SST SST49LF008A, block erase operation added
SST SST39VF6401B, block erase operation added
Amic A29010, programming algo improved
Motorola/Freescale Semic. HC908, added option "Disable suspicious trimming values warning"
Hitachi HN27C4096xx, programming algorithm improved
Altera EPC4, EPC8, EPC16, added programming of done bit
TI (TMS) MSP430F201x in ZIF, Information memory and Main memory can be programmed separately
TI (TMS) MSP430F223x/225x/227x (JTAG), power-up procedure improved
Altera EPM7032S, increasing of overcurrent protection limits
Catalyst CAT28C64B, CAT28F512, read algorithm improved
Xilinx XC17xxx [VOIC8], device package change from to VOIC8/TSOP8, manufacturer marks package with two different labels in datasheets
Xilinx XC2Cxxx, deploying of compatibility mode Xilinx XC2C32A/64A as XC2C32/64, improving of erase action
Atmel AVR-8bit, added option "override EESAVE settings", added testing of the chip protection via ISP and JTAG
Motorola/Freescale Semic. HC08, added writing of trimming value to log
