Version 2.78 features the following amendments:
Added blocking of unintentional displayed "Help" window while pressing in "Device Info" window
Added more detailed information about From-file Serialization Load file operations into Programmer activity log performed during programming of devices
Added sending of Automatic YES! setting from master site to slave sites
Fixed bug when establishing connection (EC: 5C)
Fixed bug causing error "Unknown programmer hardware (DS-HW:00)"
Fixed in Pg4uwMC - in some cases there were written incorrect information about detected programmers to Programmer activity log
Fixed in Pg4uwMC - initial information beginning with text "Welcome..." is now displayed in "Programmer activity log" immediately after start of the application
Height of "Select device" window default set to height of MainForm
Improved communication for multiprogrammers
In Pg4uwMC fixed error "Project checksum does not match between Sites..." in standalone mode when loading more various projects file by file
Logging of "AddBlankSpareArea" status improved
Atmel ATtiny48/88, power-up sequence improved
ATmel xmega series, text modification in "Device info" window
Freescale Semic. MC9S12XSxx, algorithm stability improvement
Lattice LC4128B/C/V [TQFP128], improving of overcurrent protection system
Macronix MX29NS320E [TFBGA56], support of accelerated programming mode added
Microchip PIC18F13K50/LF, PIC18F14K50/LF, size of EEPROM memory improved
Motorola/Freescale Semic. MC705J1A, MOR verify improvement
Numonyx N25Q032x13E (Quad I/O), read/verify procedure improved
Numonyx N25Q family, changed device names and backward project compatibility correction
Philips/Nxp LPC9151/9161/9171/9201/9211/922A1/9241/9251/9301/931A1/9321/9331/9341/9351/9361, User Configuration Register UCFG1, bit BOE0 added (UCFG1.3)
Samsung K9F1208R0C [FBGA63]: read and verify operations reliability improved
Samsung K9GAG08U0E [TSOP48] (HDT-01), algorithm modification upon user request
Silicon Laborat. C8051T6xx, power-up sequence improved
Silicon Laborat. Si4010, programming sequence improved
SST SST39WF1601xxxxMB [WFBGA48], programming procedure modified
STMicroelectronics ST95P08, verifying procedure improved
Toshiba TC58NVG5D2FTA00 [TSOP48], released customer support
Winbond W25Q16CV, changed device names from W25Q16CV to W25Q16CV(dc<1023) and backward project compatibility correction
Xilinx XC95216 [HQFP208], improving of overcurrent protection system
Zilog Z86E08, programming procedure improved
Atmel ATxmega32D4P, ID fixed
Atmel AT25DF321, AT25DF041A, AT25DF081, bug in programming operation fixed
Atmel AT28C64B, AT28HC64B, AT28BV64B; programming bug fixed
Atmel ATtiny20, wrong text displaying in info window after user cancel bug fixed
Atmel ATxmega64A1/128A1/192A1/256A1 [TQFP100], power-up sequence bug fixed
ESMT F25L16PA(2S) [SOIC16], programming OTP security sector bug fixed
Freescale Semic. MC9S12XEP768, MC9S12XEP100, memory map bug fixed, related to Logical (paged), Logical (paged) default, addresses DD4000h (wrong) => DD8000h (correct)
Freescale Semic. MC9S08ACxx, seldom "overcurrent on Vdd" problem fixed
Freescale Semic. MC9S12XEP768, MC9S12XEP100, project compatibility bug fixed
Intel E28F016SA [TSOP56], bug in programming operation fixed
Microchip PIC18F65J16, PIC18F66J1x, PIC18F67J11, PICmicro checksum calculation bug fixed and set of configuration bits bug fixed
Microchip dsPIC33FJ64MC20x/80x, configuration mask bug fixed
Numonyx PC28F128P30TF [EasyBGA64], insertion test bug fixed
NXP/Philips LPC1313 (ISP), device memory size bug fixed
Panasonic MN101EF31G [LQFP80], unlock Security state bug fixed
Samsung K9GAG08U0E [TSOP48] (HDT-01), ECC algorithm bug fixed
STMicroelectronics ST72F321AR9T, programming option bits procedure bug fixed
STMicroelectronics ST72F324BJ6T [TQFP44], erase procedure bug fixed
STMicroelectronics STM32F1xx in QFP64, insertion test fixed when used in DIL48/QFP694 ZIF STM32-2 adapter
STMicroelectronics M58BW016DB [PQFP80], unexpected error1 (IEC:2,D:3E) during programming fixed
Xicor X25020, programming bug fixed
Fixed bug in testing module ISP-1-20
New software - Version 2.78
