New software - Version 2.82
Posted: 27 Nov 2011 13:07
Version 2.82 features the following amendments:
Extended JobReport about informaction 'Selected Activity'
Buffer allocation procedure for SPLIT function for devices with x16 organization bug fixed
Fixed problem with selftest stop sent from remote control (Pg4uwMC)
Pg4uwMC search programmer bug fixed (spare part site identification)
Improved processing of remote control commands inside Pg4uw to reach better reaction times and less system load
Analog Devices ADP1043A, programming procedure improved
Atmel AT89LP6440, erasing parameters improvement
Epson S1C17704, erase function modified
Freescale Semic. MC9S08xx (ISP), target system power supply (TSSV) connection and reset sequence enhancement (might cause subsequent operations fail)
Hynix H8BCS0QG0ABR [FBGA107], read/verify operation stability improved
Nordic nRF24LE1, erasing procedure improved (added pages erase)
Nordic nRF24LU1P, erasing algorithm improvement
Numonyx NAND01GW3B2CZA [VFBGA63] (Thomson-PRT), file load procedure modified upon user request
NXP/Philips LPC1xxx, LPC2xxx, changed device names (ISP) to (ISP-UART)
Primarion PX8897DDQG [QFN48], added check CRC
Samsung K9F1G08U0D [TSOP48] (DWO-01), ECC algorithm modification
Spansion S29AS016JxxTxx01 [TSOP48], sectors count corrected
Spansion S29GL-N series, sector erase improved
STMicroelectronics STM32F103 "low density" devices - ID corrected
TI (TMS) CC2544 [QFN32], CC2544 (ISP), programming algorithm improvement
TI (TMS) TMS320F28035 [QFP80] and TMS320F28033 [QFP80], new programming adapter added
Xilinx CoolRunner-II, modification of designation of user register from "signature" to "usercode"
DIL48/QFP100 ZIF ispLSI-1, improving of programming adapter pinout
Atmel ATtiny2313, programming error bug fixed
Atmel ATmega165/325/645/3250/6450A/P/PA, ATmega169/329/3290/649/6490/A/P/PA, ID code bug fixed
Cypress CY7C271, CY7C274, algorithm bug fixed
Cypress CY8C5588AXI-060 [TQFP100], flash size bug fixed
IDT IDT5V49EE503, programming bug fixed
Intel JS28F256P30B [TSOP56], fixed bug during download of project file
Macronix MX29GL640EBXE [LFBGA48], insertion test bug fixed
Microchip PIC18F46K80 [TQFP44], PIC18F46K80 [TQFP44], programming procedure bug fixed
Microchip, PIC24FxxKAxxx in DIP28 package, power-up procedure bug fixed
Microchip PIC16LF1902, PIC16LF1903, device ID bug fixed
Microchip PIC18F45K80, PIC18LF45K80, PIC18F46K80, PIC18LF46K80, insertion test procedure bug fixed for QFN44 package
Microchip dsPIC33FJ64GP804, configuration mask bug fixed
NEC uPD78F04xx, synchronization procedure bug fixed
Numonyx NAND512W3A2DZA [VFBGA63] (Dataman-01), partition identification on file load bug fixed
Numonyx NAND512W3A2DZA [VFBGA63] (Dataman-01), stage1 checksum bug fixed
Numonyx/STMicroelectronics M29W640GSxxxZA [TFBGA48], insertion test bug fixed
Nuvoton M05x, algorithm bug fixed
NXP/Philips LPC1763, ID check bug fixed
NXP LPC1111/102 [HVQFN32], LPC1111/202 [HVQFN32], part IDs corrected
Renesas R5F212BCSxFP [LQFP64], erase bug fixed
STMicroelectronics STM8AF6269T, device selection bug fixed
Serialization bug fixed for all NEC Flash microprocessors
DIL48/QFP48 ZIF STM32 adapter initialization bug fixed
