Hi Neil
I have the 40PRO now (I upgraded from the S4) and trying to erase/program the TIBPAL16L8-15CN
the problem is i cannot find a device within the PAL16L8 range that the programmer will let me read it let alone erase it
the TIBPAL16L8-15CN is a Texas device and its data sheet is here
http://focus.ti.com/lit/ds/symlink/tibpal16l8-15c.pdf
the data sheet does say its functional equivalent, but faster than a PAL16L8A
I also have a PAL16R4BCN i cannot find a workable setting for. I am still trying to find a datasheet online for this IC
manufacturer: MMI
can you help? Is there a workable solution i could use?
I am using the software v2.75/12.2010 version
many thanks
Andrew
40PRO and TIBPAL16L8-15CN
Re: 40PRO and TIBPAL16L8-15CN
Hello Andrew,
The TIBPAL16L8-15CN and PAL16R4BCN devices are only supported on the Dataman48Pro+ and Pro2 range of single site and gang programmers. The Dataman-40Pro hardware is not able to program chips with a high current requirement, specifically bipolar based chips (PROM, PLD, etc.)
In order to program the TIBPAL16L8-15CN and similar devices you will need to upgrade your programmer.
Details of the D48Pro+ and Pro2 programmers can be found on our website www.dataman.com
Cheers, many thanks Neil
As i have just recently upgraded from the S4 to the 40Pro, i just dont have the justification or the money to upgrade yet again for another programmer.
thanks for the reply
Andrew
Andrew
Users browsing this forum: Ahrefs [Bot] and 24 guests
