Verify Fail! AT28HC64B
Topics related to the Dataman S6
MRI
Postby MRI » 25 Jan 2017 09:51
Hello,
I'm trying to program AT28HC64B(PLCC32). Read original-Change IC-Blank Check-Program-Verify.
Status I get:
[2017 . 01 . 25 - 10:28:06] Insert Detect
[2017 . 01 . 25 - 10:28:06] Ignore Insert Detect!
[2017 . 01 . 25 - 10:28:06] Read IC Data Ready...
[2017 . 01 . 25 - 10:28:06] Read IC Data Finish
[2017 . 01 . 25 - 10:28:06] Calculation Byte Sum in Range of [0x0000000000, 0x0000001FFF]
[2017 . 01 . 25 - 10:28:06] Calculation Byte Sum = 00001CE4F8
[2017 . 01 . 25 - 10:28:06] Read Total Checksum = 0x001CE4F8
[2017 . 01 . 25 - 10:28:06] Read IC Data Time = 0,234 s
[2017 . 01 . 25 - 10:28:07] Ignore Insert Detect!
[2017 . 01 . 25 - 10:28:07] Confirm
[2017 . 01 . 25 - 10:28:07] Confirm Done
[2017 . 01 . 25 - 10:28:07] Confirm Time = 0,202 s
[2017 . 01 . 25 - 10:29:12] Insert Detect
[2017 . 01 . 25 - 10:29:12] Ignore Insert Detect!
[2017 . 01 . 25 - 10:29:12] Blank Check
[2017 . 01 . 25 - 10:29:12] Blank Check Done
[2017 . 01 . 25 - 10:29:12] Blank Check Time = 0,124 s
[2017 . 01 . 25 - 10:29:23] Insert Detect
[2017 . 01 . 25 - 10:29:23] Ignore Insert Detect!
[2017 . 01 . 25 - 10:29:23] Program
[2017 . 01 . 25 - 10:29:24] Progam Finish
[2017 . 01 . 25 - 10:29:24] Progam Time = 1,326 s
[2017 . 01 . 25 - 10:29:28] Insert Detect
[2017 . 01 . 25 - 10:29:29] Ignore Insert Detect!
[2017 . 01 . 25 - 10:29:29] Verify
[2017 . 01 . 25 - 10:29:29] Verify Mode = 8 Bits
[2017 . 01 . 25 - 10:29:29] Verify Error Address = 0x00000000, Verify Data = 0x008F, Error IC Data = 0x00FF
[2017 . 01 . 25 - 10:29:29] Verify Fail!
I tried with XICOR X28HC64(PLCC32), but same result.
Programmer Software: 5.3.9.2 Database 20170113 ;Win7
Could anyone help me?
Thanks in advance.
Re: Verify Fail! AT28HC64B
Postby Dataman (Neil Parker) » 25 Jan 2017 11:51
Hello MRI,
I can see that your software and database versions are up to date, can I ask why you need to disable the Insertion detection for this chip? Does it produce an error if it is enabled, what is the error message?
The recommended adaptor sockets for this device in the PLCC32 package are LP-PLCC-1M32 or LP-PLCC-1M32S, both are straight through pin1 to pin1, pin32 to pin32. Does this match your adaptor socket?
MRI
Postby MRI » 25 Jan 2017 17:08
Hi Neil,
Thank's for fast response.
I checked my adaptor socket. It's straight through all pins available. S6 self test passed.
I get error if i use Insertion detection on both AT28HC64 and X28HC64 same:
[2017 . 01 . 25 - 17:50:31] SN Read
[2017 . 01 . 25 - 17:50:31] SN Read Done
[2017 . 01 . 25 - 17:50:32] Detect Dataman-S6 Compact USB Programmer
[2017 . 01 . 25 - 17:50:32] Firmware Number Get
[2017 . 01 . 25 - 17:50:32] Firmware Number = 1
[2017 . 01 . 25 - 17:50:32] Firmware Number Get Done
[2017 . 01 . 25 - 17:50:32] Firmware Version Get
[2017 . 01 . 25 - 17:50:32] Firmware Version = 1.9E
[2017 . 01 . 25 - 17:50:32] Firmware Version Get Done
[2017 . 01 . 25 - 17:50:32] No Updates Are Required
[2017 . 01 . 25 - 17:50:39] Hardware Init Setting
[2017 . 01 . 25 - 17:50:39] Hardware Init Setting Done
[2017 . 01 . 25 - 17:50:39] Driver INI Setting
[2017 . 01 . 25 - 17:50:39] Driver INI Setting Done
[2017 . 01 . 25 - 17:50:39] Check CRC32 of Driver
[2017 . 01 . 25 - 17:50:39] Check CRC32 of Driver Done
[2017 . 01 . 25 - 17:50:39] FPGA Init
[2017 . 01 . 25 - 17:50:40] FPGA Init Done
[2017 . 01 . 25 - 17:50:40] Device Select = ATMEL - AT28HC64B(PLCC32)
[2017 . 01 . 25 - 17:50:40] <Note>================================================
[2017 . 01 . 25 - 17:50:45] Insert Detect
[2017 . 01 . 25 - 17:50:46] Pin 12 of IC is Fail!
[2017 . 01 . 25 - 17:50:46] Pin 17 of IC is Fail!
[2017 . 01 . 25 - 17:50:46] Pin 26 of IC is Fail!
[2017 . 01 . 25 - 17:50:46] PinScan = 0xF00F700001DFE
[2017 . 01 . 25 - 17:50:46] Insert Detect Fail!
Michael
MRI
Postby MRI » 01 Feb 2017 08:20
Any idea?
Postby Dataman (Neil Parker) » 01 Feb 2017 08:54
Hello Michael,
Apologies for the delay, please install the latest database from our website here, our engineers have made some improvements to the algorithm for the 28HC64B.
Please let me know if the situation improves.
MRI
Postby MRI » 01 Feb 2017 15:48
Hello Neil,
Insertion detection is passing now, but program still doesn't work.
[2017 . 02 . 01 - 15:55:01] Load File Finish
[2017 . 02 . 01 - 15:55:01] Total Memory Checksum = 0x001CE4F8
[2017 . 02 . 01 - 15:55:06] Insert Detect
[2017 . 02 . 01 - 15:55:06] Insert Detect Done
[2017 . 02 . 01 - 15:55:06] Blank Check
[2017 . 02 . 01 - 15:55:06] Blank Check Done
[2017 . 02 . 01 - 15:55:06] Blank Check Time = 0,125 s
[2017 . 02 . 01 - 15:55:12] Insert Detect
[2017 . 02 . 01 - 15:55:12] Insert Detect Done
[2017 . 02 . 01 - 15:55:12] Program
[2017 . 02 . 01 - 15:55:13] Progam Finish
[2017 . 02 . 01 - 15:55:13] Progam Time = 1,328 s
[2017 . 02 . 01 - 15:55:17] Insert Detect
[2017 . 02 . 01 - 15:55:17] Insert Detect Done
[2017 . 02 . 01 - 15:55:17] Verify
[2017 . 02 . 01 - 15:55:17] Verify Mode = 8 Bits
[2017 . 02 . 01 - 15:55:17] Verify Error Address = 0x00000000, Verify Data = 0x008F, Error IC Data = 0x00FF
[2017 . 02 . 01 - 15:55:17] Verify Fail!
Michael
Postby Dataman (Neil Parker) » 06 Feb 2017 10:07
Hello Michael,
Our engineers have made some more improvements to the algorithm for this device, please download and try the latest version here.
MRI
Postby MRI » 06 Feb 2017 13:25
Hello Neil,
I tested new database but unfortunately no Progress. Same verify fail message like before.
Michael
Postby Dataman (Neil Parker) » 07 Feb 2017 08:53
Hello Michael,
Thank you for the feedback. At this point we are going to have to ask if it is possible for you to provide 2 samples of this device for testing in our lab, since we can no longer get them from Atmel...
MRI
Postby MRI » 08 Feb 2017 14:38
Hello Neil,
in this case I would like to continue investigation with XICOR X28HC64 device.
Right now same situation. Verify Fail after Program.
Please tell me if you need samples.
Michael
Return to “Dataman S6”
