Programming adapter test-error
Posted: 20 Feb 2017 23:48
At my work place, we use Dataman448Pro2 with PLCC32 adapter only.Last night, for the first time I tried to use this programmer to read data from TSOP48 NAND flash.To achieve that, I've purchase this universal TSOP48 adapter:
http://www.ebay.co.uk/itm/281773347998? ... EBIDX%3AIT
If I try to read content of the NAND flash, I get "programming adapter test-error" message.
At this point, I thought that my NAND IC (TC58DVM92A5TA10) was not supported. I checked the device support list,and the closest to mine NAND chip is TC58DVM92A5TA00.(I've tried both TC58DVM92A5TA00 and TC58DVM92A5TA00 (T&W-01)
Then, I put back the PLCC32 adapter without chip, hit the READ button and I got "missing chip or chip not present" like message which is totally obvious at this point. When I tried to do the same with TSOP48 adapter, I didn't even get that message, instead once again "Programming adapter test-error"
Does it mean, that my tsop48 adapter is not compatible with this programmer?Maybe I should change some settings in Dataman software?
Thanks in advance.
Thanks in advance.
