The programming about DS1302
viwar
Postby viwar » 20 Apr 2017 10:01
Hello~
I would like to ask a question about the programming of DS1302. I brought another control module in the program of DS1302.Here the timer2 is setted to interrupt,but it can’t response after brought the timer t0 interruptions. Then as a result: the t0 can’t be controlled when interrupting.How to solve the problems?
The datasheet of DS1302: http://www.kynix.com/uploadfiles/pdf0125/DS1302N.pdf
program:
Code: Select all
#include<reg52.h> #include<intrins.h> #define uchar unsigned char #define uint  unsigned int uchar dis_time_buf[16]={0}; sbit pwm_v=P0^7;//Horizontal signal sbit pwm_h=P1^7;//Perpendicular to the direction of the signal uchar sev; uchar seh; uchar count;//t0 the time of interruption //LCD pin definition sbit RS = P1^0;   // define the port sbit RW = P1^1; sbit EN = P2^5; #define RS_CLR RS=0 #define RS_SET RS=1 #define RW_CLR RW=0 #define RW_SET RW=1 #define EN_CLR EN=0 #define EN_SET EN=1 #define DataPort P0 //DS1302 pin definition sbit RST=P2^0; sbit IO=P2^1; sbit SCK=P2^2; //DS1302 address definition #define ds1302_sec_add                            0x80                   //seconds data address #define ds1302_min_add                           0x82                   //seconds data address #define ds1302_hr_add                     0x84                   //times data address #define ds1302_date_add                          0x86                   //days data address #define ds1302_month_add             0x88                   //months data address #define ds1302_day_add                            0x8a                   //weeks data address #define ds1302_year_add                          0x8c          //years data address #define ds1302_control_add            0x8e                   //controlling data address #define ds1302_charger_add          0x90                                                #define ds1302_clkburst_add          0xbe //Initial time definition uchar time_buf[8] ={0x20,0x17,0x04,0x08,0x21,0x38,0x55,0x06};// /*------------------------------------------------ uSdelay function,include input value unsigned char t,not returned value unsigned char is the variable of characters,the degrees of value is 0~255 crystal oscillator=12M,delaying T=tx2+5uS ------------------------------------------------*/ void DelayUs2x(unsigned char t) {    while(--t); } /*------------------------------------------------ mS delay function,include input value unsigned char t,not returned value unsigned char is the variable of characters,the degrees of value is 0~255 crystal oscillator=12M, ------------------------------------------------*/ void DelayMs(unsigned char t) {       while(t--) {     //delay 1mS     DelayUs2x(245);           DelayUs2x(245); } } //function bitLCD_Check_Busy(void) { RS_CLR; RW_SET; EN_CLR; _nop_(); EN_SET; return (bit)(DataPort & 0x80);//0x80;0x00 } //the writing function of ordering voidLCD_Write_Com(unsigned char com) {   while(LCD_Check_Busy()); /wait if busying RS_CLR; RW_CLR; EN_SET; DataPort= com; _nop_(); EN_CLR; } //the function of writing data voidLCD_Write_Data(unsigned char Data) { while(LCD_Check_Busy());//wait if busying RS_SET; RW_CLR; EN_SET; DataPort= Data; _nop_(); EN_CLR; } //clear function voidLCD_Clear(void) { LCD_Write_Com(0x01); DelayMs(5); } //writing characters function voidLCD_write_char(unsigned char x,unsigned char y,unsigned char Data) {      if(y == 0)         //set coordinate         {            LCD_Write_Com(0x80 + x);              }    else         {            LCD_Write_Com(0xC0 + x);              }       LCD_Write_Data( Data);   } //LCD initialize function voidLCD_Init(void) {   LCD_Write_Com(0x38);    /*display the set module*/   DelayMs(5);   LCD_Write_Com(0x38);   DelayMs(5);   LCD_Write_Com(0x38);   DelayMs(5);   LCD_Write_Com(0x38);     LCD_Write_Com(0x08);    /*close shows*/   LCD_Write_Com(0x01);    /*display clear*/   LCD_Write_Com(0x06);    /*show the move set*/   DelayMs(5);    LCD_Write_Com(0x0C);    /*display opening*/    } //DS1302initialize function void ds1302_init(void) {          RST=0;                        //RST          SCK=0;                        //SCK } //write the first data in DS1302 void ds1302_write_byte(uchar addr, uchar d) {          uchari;          RST=1;                                           //start DS1302 line                //write the aim address:addr          addr= addr & 0xFE;   //          for(i = 0; i < 8; i ++) {                    if(addr & 0x01) {                             IO=1;                             }                    else{                             IO=0;                             }                    SCK=1;      //produce time                    SCK=0;                    addr= addr >> 1;                    }                  //writing data:d          for(i = 0; i < 8; i ++) {                    if(d & 0x01) {                             IO=1;                             }                    else{                             IO=0;                             }                    SCK=1;    /produce time                    SCK=0;                    d= d >> 1;                    }          RST=0;               //stop DS1302 line } void Display(void) {       LCD_write_char(3,0,dis_time_buf[0]+'0');       LCD_write_char(4,0,dis_time_buf[1]+'0');       LCD_write_char(5,0,dis_time_buf[2]+'0');       LCD_write_char(6,0,dis_time_buf[3]+'0');   LCD_write_char(7,0,'/');           LCD_write_char(8,0,dis_time_buf[4]+'0');       LCD_write_char(9,0,dis_time_buf[5]+'0');   LCD_write_char(10,0,'/');       LCD_write_char(11,0,dis_time_buf[6]+'0');       LCD_write_char(12,0,dis_time_buf[7]+'0');           LCD_write_char(15,0,dis_time_buf[14]+'0');    //show in the second         LCD_write_char(3,1,dis_time_buf[8]+'0');      LCD_write_char(4,1,dis_time_buf[9]+'0');   LCD_write_char(5,1,':');      LCD_write_char(6,1,dis_time_buf[10]+'0');       LCD_write_char(7,1,dis_time_buf[11]+'0');   LCD_write_char(8,1,':');       LCD_write_char(9,1,dis_time_buf[12]+'0');       LCD_write_char(10,1,dis_time_buf[13]+'0'); } //timer 0 intilization void t0( ) { TMOD=0x01; TH0=0xfe; TL0=0x33;//0.5ms EA=1; ET0=1; PT0=1;// TR0=1; } //timer 0 interrupt function void Time0( )interrupt 1 {          TH0=0xfe;          TL0=0x33;//装初值0.5ms        if(count<sev)//                    pwm_v=1;          else                    pwm_v=0;          if(count<seh)//                    pwm_h=1;          else                    pwm_h=0;                    count=(count+1);                    count=count%40;//cycle is 20ms } //timer 2 interrupt function void Timer2() interrupt 5   //定时器2是5号中断 { static uchar t; TF2=0; t++; if(t==4)               //间隔200ms(50ms*4)读取一次时间   {   t=0;   ds1302_read_time();  //the reading time   dis_time_buf[0]=(time_buf[0]>>4); //year      dis_time_buf[1]=(time_buf[0]&0x0f);       dis_time_buf[2]=(time_buf[1]>>4);     dis_time_buf[3]=(time_buf[1]&0x0f);              dis_time_buf[4]=(time_buf[2]>>4); //month     dis_time_buf[5]=(time_buf[2]&0x0f);       dis_time_buf[6]=(time_buf[3]>>4); //day     dis_time_buf[7]=(time_buf[3]&0x0f);       dis_time_buf[14]=(time_buf[7]&0x07); //month        //show in the second     dis_time_buf[8]=(time_buf[4]>>4); //time     dis_time_buf[9]=(time_buf[4]&0x0f);        dis_time_buf[10]=(time_buf[5]>>4); //second    dis_time_buf[11]=(time_buf[5]&0x0f);      dis_time_buf[12]=(time_buf[6]>>4); //second   dis_time_buf[13]=(time_buf[6]&0x0f);       } }
Thanks ~
Wishes~
Re: The programming about DS1302
Postby Dataman (Neil Parker) » 20 Apr 2017 10:38
Hello viwar,
Thank you for posting in our forum. Unfortunately we are not able to help with authoring or modifying the code within a device, our main focus is to take the compiled code in hex or binary file format and program this data into the device using our hardware programmers.
If you have any problems using our programmers then we are able to help.
We do not currently support the Dallas DS1302 Trickle-Charge Timekeeping Chip but if you would like us to look at the possibility of implementing the support into our programmers then please let me know.
