New software - Version 2.88
Posted: 10 Apr 2012 14:56
Version 2.88 features the following amendments:
Fixed error "File access error" with text "Unable to create configuration file.", that could occur when action Save project, with the same file name as recently loaded project, was performed, and existing project file is older date and has obsolete format
Fixed Protected Mode in PG4UW to prevent hazard of using Repetitive mode with "Fill random data to buffer" option active
Reading setting for Suspend on error from INI file bug fixed
Modified dialog Menu/Buffer/Checksum, added possibility to "exclude block(s) from checksum calculation" also in Checksum calculator tab
Fixed bug in PG4UWMC warning: "A component named bh4label1 already exists."
PG4UWMC: added new feature of operation protection, new modes: Operator Mode and Administrator Mode that replace former Protected and Normal modes
ABOV Semiconductor MC96F7816, programming speed increased
Altera MAX II, MAX V, device identification improvement
ASIX AX11005 [LQFP80], verify procedure improved
Atmel AT90PWM3/3B [SOIC32](SPI), power-on sequence improved
eMMC devices, programming of the Authentication Key improved
eMMC devices, programming password stability improved
Eon Silicon Sol. EN25S32, programming improved
Freescale Semic. MC908LJ12, MC68HC908LJ12 [QFP64], power-up sequence adjusted
Freescale Semic. MC9S12DG256B (ISP), communication synchronization adjusted
Generalplus GPM8F family, algorithm improvement
Huawei SD5000V100 [LQFP176], SD5000V200 [TFBGA208], verify operations improved
Macronix MX25Ux033E devices, programming stability improved
Microchip PIC32MX4xx, added set of UPLLDIV and UPLLEN bits
Micron MT29F1G08ABADAH4 [VFBGA63] (HUMAX-01), custom algorithm modification upon user request
Micron MT29F1G16ABBDAH4 [VFBGA63], read/verify operation stability improved
Micron N25Q512Ax3G, showing of erase process improved
NEC/Renesas uPD70Fxxx, uPD78Fxxx (ISP), added clock from programmer
NEC/Renesas uPD78F054x, uPD78F054xA, programming speed increased
NEC/Renesas uPD78F116x, uPD78F116xA, programming speed increased
NEC/Renesas uPD78F9136B, programming procedure improved
NXP LPC1102UK [WLCSP16], picture of position reference point in device info changed
OKI MR48V256A, improving of pin assignment
Samsung S3P8245 [QFP80], erase action disable
Spansion FL-S family with uniform 256-kB sectors, programming time improved
Spansion FL-S family, Programming Status and Configuration Register improved
Spansion S25FL128P, checking after programming of Status Register improved
Spansion S29AL008JxxTxx02 [TSOP48], Programming procedure improved
TI (TMS) LM3S2965, power-up sequence improved
TI (TMS) LM3S5B91, programming time improved
TI (TMS) LM3S5R36, LM3S5T36, Programming improved
TI (TMS) TMS320F28PLC83, log information in case of verify error modified
TI (TMS) TMS320F28PLC83, verification of OTP area modified
TI (TMS) TMS320F28PLC83, verifying and programming of OTP area modified
Winbond W25QxxxFV family, Security registers Blank Check improved
Altera EPM2210G [FBGA324], pgm. parameters assignment bug fixed
Atmel AVR series, double write of the text "Chip protected" in programming routine bug fixed
Freescale Semic./Motorola MC68HC705Jx7, power-up sequence bug fixed
Huawei SD5000V200 [TFBGA208], bug in verify operation fixed
Hynix HY27UG088G5B [TSOP48], ID check bug fixed
CHiL Semiconductor CHL8112A (ISP), verification bug fixed
Intel PC28F00AP30EF [EasyBGA64], "Unexpected error 1 [IEC:2, D:04]!" error fixed
Micron MT29F1G16ABBDAH4 [VFBGA63], ID check problem fixed (all 00h read)
Nec/Renesas uPD70F3377A, synchronization procedure bug fixed
Numonyx PC28F00BM29EWH [BGA64], bug in programming operation fixed
NXP LPC1104UK [WLCSP16], power-down sequence bug fixed
Ramtron FM21L16, FM22L16, FM21LD16, FM22LD16, FM23MLD16, programming bug fixed
Silicon Laborat. Si101x, memory capacity bug fixed
TI (TMS) LM3S5T36, programming bug fixed
Winbond W25Q128FV, setting of Security registers in Special options fixed
Winbond W25Q128FV [SOIC16], Programming device error fixed
Xilinx XC95xxx, parameters assignment bug fixed for erase action
