New software - Version 3.32
Posted: 12 May 2017 15:16
Version 3.32 features the following amendments:
Credit box, small improvements
"Fill buffer block" operation (shortcut Ctrl+F2) now allows to set erase value in Byte, or 16/32 bit Word format
Fixed error "Cannot open clipboard.", that could sometimes occur during "Create problem report" operation
Adapter DIL48/QFN20-1.02 ZIF PIC-1, insertion test improved
Added support of DIL48/QFN40-2.02 ZIF ISL-2
Added support of DIL48/QFN40-2.02 ZIF TPS53-2
Added support of DIL48/QFN40-3.01 ZIF-CS TPS549-1
Added support of DIL48/QFP128 ZIF PLD-1
Analog Devices ADUCM320, programming improved
Atmel/Microchip AT89C51CC03, programming procedure improved
Atmel AT89C51RD2, verify errors listing improved
Atmel ATSAM4E8E, programming of GPNVM bits improved
Atmel ATSAM4S, power-on procedure improved
Atmel ATV750B, improving of overcurrent protection system
eMMC devices, View/Edit of the Partition Table improved
Intel PF38F5060M0Y0 [SCSP107], adapter identification procedure improved
Lattice ispLSI5128VE [TQFP128], ispLSI5256VE [TQFP128], pgm parameter assignment improved
NXP/Philips LPC2103, ID check procedure improved
Renesas R5F5631ExxFB [LQFP144], Boot mode communication speed increased
Renesas RH850 Family, programming and verification procedure for Code Flash improved
Silicon Laborat. C8051T6xx, programming security byte procedure improved
TI (TMS) TMS320F28069, operations with device speedup
Toshiba TMP89FS60FG (ISP-UART), programming improved
Atmel/Microchip AT89LPxxxxx [MLF44], pinout bug fixed
BGA-Top-243 ZIF-CS, prog. adapter name bug fixed
Cypress CY8C5867LTI-LP025 [QFN68], Unexpected error 1 [IEC:1, D:51] bug fixed
GigaDevice Semic. GD25Q80C [SOP8-150], adapter bug fixed
Lattice ispPAC-POWR1014A-01 [TQFP48], pgm parameter assignment bug fixed
Lattice M4A5-94/48 [TQFP100], pgm parameter assignment bug fixed
Microchip dsPIC33FJ Family, device ID check bug fixed
Microchip dsPIC33FJ12MC202, programming procedure bug fixed
Microchip PIC32MZxxxEFx Family, programming of configuration bits bug fixed
Micron/Numonyx/Intel JS28F064M29EWH [TSOP56], insertion test bug fixed
Micron MT29F2G08ABAEAH4 [VFBGA63] (EPS-13), some bugs in invalid blocks management fixed
Motorola/Freescale Semic. MC9S12DG, B, KT, A families in QFP80, Unexpected error 1 [IEC:1, D:1A] bug fixed
Renesas R7F701402/14, activate ICU-S bug fixed
Spansion S29GL064AxxFxxR5 [FBGA64], insertion test bug fixed
SST SST34HF1641J [LFBGA56], Unexpected error 1 [IEC:2, D:02] bug fixed
TI (TMS) MSP430Fxxx in BSL mode, Unexpected error 1 [IEC:2, D:0E] bug fixed
TI (TMS) TIBPAL16L8-7, pgm parameter assignment bug fixed
TI (TMS) TMS320F28065 [QFP100], programming and erase bug fixed
Toshiba TMP91FW60DFG (ISP), verify after programming bug fixed
Winbond W25Q80DV, Security registers bug fixed
