New software - Version 2.90
Posted: 03 Jul 2012 16:10
Version 2.90 features the following amendments:
All PG4UW applications ran from PG4UWMC are now set to Protected Mode, regardless if the PG4UW has Master or Slave status
Fixed problem with minimalization of PG4UW applications started in multiprogramming mode from PG4UWMC
Optimized buffer, especially for large devices (over 1GB)
Released function Check ZIF socket empty for PG4UWMC remote control
Atmel AT28C64, insertion test improved
Atmel ATmega1284P, power-on sequence improved
Atmel ATmega325/3250, power-on sequence improved
Atmel ATmega325/3250, programming improved
Atmel Serial Flash in ISP mode, added option - disable programmed chip supply voltage test
BGA-Bottom-263, pgm. parameters assignment improved
BGA-Bottom-264, pgm. parameters assignment improved
DIL48/QFP208 ZIF PLD-14, pgm. parameters assignment improved
Freescale Semic. MC68HC705JJ/JP7, Vtst during bootstrap mode raised
Generalplus GPM8Fxxx [SSOP30], menu View/Edit option registers improved
LatticeXP2, pgm. parameters assignment improved
Maxim MAX16065, programming procedure improved
Microchip PIC18F26K80, power-on procedure improved
Microchip PIC18F66K22, programming procedure improved
Micron MT29F1G08ABADAH4 [VFBGA63] (HUMAX-01), user algorithm modification upon customer's request
Numonyx JS28F512M29EWH [TSOP56], program and verify operation improved
Numonyx M58BW016FB [PQFP80], ID check and verify operations improved
Nuvoton ISD15102, device ID check improved
Nuvoton ISD15102, read/verify/blank check reliability improved
Philips/Signetics S87C75x, added reading security bits (View in Alt+S menu)
Sigma Designs SD3402, programming improved
Silicon Laborat. C8051F047, programing procedure improved
Spansion S71WS128PC0HF3S [FBGA84], power-up sequence modified
Spansion S71WS256PC0HF3S [FBGA84], power-up sequence modified
Spansion S71WS512PD0HF3T [FBGA84], power-up sequence modified
STMicroelectronics ST7FOXK1T6 (ICP OPT Disable), programming speed improved
STMicroelectronics STM8L151G6Y, SWIM protocol improved
STMicroelectronics STM8TL53G4U [UFQFPN28], insertion test modified
TI(TMS) MSP430F24x/F23x/F241x BSL in ZIF mode, MSP430F24x/F23x JTAG in ZIF mode, Information memory and Main memory can be programmed separately
ZMD U631H64; Power-on sequence improved
Atmel AT27C2048, ID check error fixed
Atmel ATmega3290A, ID check bug fixed
Atmel ATmega640/1280/2560 [CBGA100], "unexpected error" fixed
Atmel ATtiny1634, BODLEVEL values fixed
Atmel ATtiny28L/V [MLF32], insertion test bug and pinout bug fixed
Atmel ATxmega A1 family, BODLEVEL values modification
Atmel ATxmega A3U/A4U/D4 families, BODLEVEL values fixed
ATO Solution AFND5608S1 [FBGA48], adapter assignment information fixed
Freescale Semic. MC68HC705JP7 [SOIC28], device communication error fixed
Fujitsu microcontrollers, serialization bug fixed
GigaDevice Semic. GD25Q128B [SOP16], OTP area programming bug fixed
Microchip dsPIC30F5013, programming procedure and insertion test bug fixed
Microchip PIC18F4431, programming procedure bug fixed
Microchip PIC18F66K22, power-on procedure bug fixed
Microchip PIC18F8722, load/save project files bug fixed
Microchip PIC32MX1xx, PIC32MX2xx in TQFP44 package, insertion test bug fixed
Microchip PIC32MX3xx, PIC32MX4xx, load/save procedure bug fixed
Microchip PIC32MX4xx, load hex file bug fixed
Microchip PIC32MX4xx, PICmicro checksum calculation bug fixed
Micron MT29F1G08ABADAH4 [VFBGA63] (HUMAX-01), additional invalid blocks check bug fixed
Micron MT29F2G08ABAEAH4-E [VFBGA63], internal ECC controller enabling fixed
Micron PC28F00AG18F [EasyBGA64], bug in erase operation fixed
Numonyx PC28F256M29EWHD [BGA64], test of Protection mode state improved
Nuvoton NUC100RE3 [LQFP64], programming procedure bug fixed
Programming address bug fixed for device family RX62N and RX621
Renesas R5F21334DxFP [LQFP32], device settings window bug fixed
Spansion S29AL004DxxMxx01 [PSOP44], insertion test bug fixed
Spansion S29AL004DxxMxx02 [PSOP44], insertion test bug fixed
Spansion S71VS128RBOAHK3L [FBGA56], "Programmer communication error (P:YP/EC:01)!" bug fixed
TI (TMS) LM3S9D90 [LQFP100], problem with overcurrent fixed
TI (TMS) UCD90160 [QFN64] (P+D), verify/blank check error bug fixed
Xilinx XC95108 [PLCC84], programming parameters assignment bug fixed
