Dataman 48LV connected by usb converter
Posted: 11 Nov 2011 11:40
by Guest
I want to know if it is possible to connect the Dataman-48LV by a IEEE-1284 compatibel parallel - USB converter.
We have plans to order a new notebook without any parallel connector. I want to connect the dataman-48LV via a usb converter.
If anyone have the experience please let me know
EvdHoeven
Re: Dataman 48LV connected by usb converter
by Dataman (Neil Parker)
Unfortunately due to that fact that the D48 uses the parallel port in a non standard way does not allow for the USB to parallel converter to be used. You should be able to find a PCMCIA card to parallel port adaptor which should work correctly.
Hope this helps.
by Guest
I have tried to use a PCMCIA - parallel card which is ( as it says ) ecp/epp/ spp / bpp IEEE1284c. But it does'nt work. I think dataman software communicate directly tot a parallel port and not via Windows drivers which are used to support the PCMCIA card.
Are there any other suggestions?
EvdHoeven
Posted: 11 Nov 2011 11:41
As you have discovered the Dataman uses the parallel port in a non standard way. This is why you have not had any success with the PCMCIA card.
There is no other solution other than using the built in port on a PC. I appreciate that not all newer laptops and even now some desktops have a parallel port built in.
You could upgrade your programmer to the UXP model which has a USB connection.
