Version 2.97 features the following amendments:
New in Custom generator serialization, support for no-number format of Current/Next/Last serial "number". Now any string, except spaces, can be used
In dialog Serialization, when confirm settings for Custom generator serialization, no generator call is performed. Settings are passive only
In dialog Serialization for Custom generator serialization is added new button "Test serialization settings by call for generator"
Fixed error with comparing serial numbers in custom generator serialization, that sometimes occurred, when checking Current serial number (line T01:...) with Current serial number in PG4UW software
Fixed problem with no creating of Job report and zero statistics summary in Programmer activity log, when closing PG4UW application in Protected Mode
Fixed unwanted twice call of generator for Custom generator serialization when error ocured
Added button "Connect all sites" and relevant routines to run all sites with one click in demo application MultiDemo
Changed default value for setting "Auto hide on start"=false for PG4UWMC window after the Remote control interface was started, changed method used to hide
Improved ZIF socket actuation unit control application
ABOV Semiconductor MC80F0604, erasing procedure improved
ABOV Semiconductor MC80F0604, power-up sequence modified
Cypress CY8C3xxxxxx, CY8C5xxxxxx, Set security default state changed to Disable
DIL48/LQFP100-1 ZIF R5F-1# prog. adapter name changed to DIL48/QFP100-1 ZIF R5F-5#
DIL48/LQFP100-2 ZIF R5F-1# prog. adapter name changed to DIL48/QFP100-2 ZIF R5F-5#
DIL48/QFP64 ZIF FM3-1, improving of programming adapter pinout
Energy Micro EFM32G210F128, programming procedure improved
Fujitsu MB96F61x/MB96F62x/MB96F67x/MB96F68x, power-up sequence modified
Infineon TC1767, added skipping of blank pages during programming
Intel DT28F016SV [SSOP56], read procedure changed
Lattice LC4256V (ISP), pgm. parameter assignment and pgm. actions improved
Lattice LCMXO2-4000HC [caBGA332], pgm. parameter assignment improved
Lattice MachXO2, pgm. parameter assignment improved
Maxim MAXQ612, erasing procedure improved
Mitsubishi/Renesas M37630E4FP [QFP44], programming adapter changed
Programming adapter DIL48/QFP100 ZIF PLD-20, pgm. parameter assignment improved
Samsung K9F2G08U0C [TSOP48], read and verify operations stability improved
STMicroelectronics STM32L1xx family, Option Bytes processing improved
STMicroelectronics STM32L1xx with 256kB flash memory, blocked USER byte setting that might enable booting from nonexistent flash memory bank 2
STMicroelectronics STM8L151G3U (ISP), communication speed improved
STMicroelectronics STM8T143, programming and verifying procedure improved
SunplusIT SPCP866E2A, programming procedure improved
Toshiba TMP87PM29U [LQFP64],TMP87PH48U [LQFP64],TMP87PM48U [LQFP64], programming adapter changed
Xilinx XC3S1400AN [FBGA676], pgm. parameter assignment improved
Adapter DIL48/TQFP80 ZIF HD64-4, identification bug fixed
Altera EPM5032, Cypress CY7C344B, pgm. parameter assignment bug fixed
cFeon(Eon Si.Sol.) EN25QH16, device ID check and other errors fixed
Cypress CY8C21512 (ISP), selected device bug fixed
ESMT F25D64QA [SOIC8-200], programming adapter assign corrected
Freescale Semic. MC9S08GT16A [QFN32], Insertion test error fixed
Freescale Semic. MC9S08QG8 [QFN16], Insertion test error fixed
Freescale Semic. S9S12VR48 [LQFP32], adapter error fixed
Hitachi HD64F2329BVF, memory size bug fixed
Intel DT28F016SV [SSOP56], program and erase bug fixed
Intel RD48F4400L0YBP0 [SCSP137], erase procedure bug fixed
Lattice ispLSI1032E [TQFP100], pgm. parameter assignment and insertion test improved
Maxim MAXQ610J, fixed problem with creating of Job Report
Microchip PIC18FxxK90, set of WDTPS bits bug fixed
Microchip PIC18F2xxx, PIC18F4xxx, programming procedure bug fixed
Microchip PIC18F23K20, programming procedure bug fixed
Microchip PIC24FVxxKA301 [SOIC20], programming adapter DIL40/SOIC20 ZIF PIC-1 test improved
Microchip PICxxx, dsPICxxx, marginal verification bug fixed
NEC, uPD70F3634, synchronization procedure bug fixed
NEC/Renesas uPD78F055x (ISP), synchronization procedure bug fixed
Ramtron FM24W256 [SOIC8-150], adapter assignment fixed
Samsung K9HCG08U5D [WLGA52], adapter assignment fixed
Samsung S3F9488, missing Smart option programming repaired
STMicroelectronics STM32F05x family, RDP byte checking bug fixed
STMicroelectronics STM32F3xx family, RDP byte checking bug fixed
TI (TMS) LM3Sxxxx, overcurrent error fixed
Toshiba TMPM374FWUG [LQFP44], "Unexpected error 1 [IEC:2, D:3E]!" error fixed
New software - Version 2.97
