New software - Version 3.36
Posted: 28 Nov 2017 12:14
Added module: AP1 BGA64-2.1 ZIF NOR-8
Added module: AP1 QFN40 ZIF SiM-1
Added module: AP1 QFN56-2.02 ZIF CC-1
Added module: AP1 QFN64 ZIF SiM-1
Added module: AP1 QFP100-1.02 ZIF R5F-7
Added module: AP1 QFP32-1.04 ZIF R5F-1
Added module: AP1 SSOP20-155 ZIF ET-1
Atmel ATmega644/1284/2564RFR2 [VQFN48], added support
GigaDevice Semic. GD25D10B [TSSOP8], AP1 module insertion test bug fixed
Serial NAND flash devices in SOP16 package, Unexpected error 1 [IEC:2, D:3E]! fixed
Winbond W25Q128JVxxQ [SOIC8-200] (QuadSPI), verify bug fixed
