New software - Version 3.38
Posted: 07 Feb 2018 15:11
In PG4UWMC removed unwanted warning "Device operation could not be performed, because previous "Device operation" operation still not finished." when user is changing device operation type (from program to blank check for example) and trying to start the new operation
Added module: AP1 BGA400-2 ZIF PLD-1
Added module: AP1 BGA63-1.10 ZIF NAND-1 (LD)
Added module: AP1 QFN40-2.02 ZIF PX-2
Added module: AP1 TSSOP20 ZIF 170mil NUC-1
GigaDevice GD32 in LQFP64 and LQFP100 packages, insertion test fixed
STMicroelectronics STM32 in LQFP64 and LQFP100 packages, insertion test fixed
