27C801 programming
Posted: 14 Nov 2011 16:05
Hi there,
I have a couple of questions on the 27C801 chip. I read through the forums and there was 1 reference to this particular chip but it still did not answer my question. I am familiar with using the S4 as i have used it for the last 10 years with great sucess. I have never had to program an 8mg chip before and i am really doing this as a favor for a friend. My S4 does have 512k memory. So my questions are as follows;
1. I have a master eprom i want to copy. When i do the load i set the memory to 00000-7FFFF#80000 is this correct?
2. I do the checksum on the ROM the last address is FFFXX and the checksum appears. Assuming the FFFXX is the additional memory area.
3. I send the file to the PC my file size is 1267kb which sounds correct for an 8mg chip.
4. I have downloaded the file splitter you recomended and have tried several diferent ways to burn the chip. But using the procedure you stated in a previous post (12/20/2006 @ 12:32:29 PM) i cannot program my S4 to the different memory areas to download. I am rather confused on this procedure.
5. Once the file is split....downloaded and burnt to the chip, how do i verify the checksum when the RAM checksum limits me to 00000-7FFFF?
ANY and all help will be greatly appreciated. Thanks in advance!
GMalicote
GMalicote
